Find the primitives of the functions secx tanx
  • Thread starter Thread starter Taryn
    Functions
11 replies · 3K views
Taryn
hey just wondering if someone could help me with these 2 questions!
Suppose for a function f, that 1<= f'(x)<=3 show that
4<=f(6)-f(2)<=12
I don't even no where to start... I was thinkin that in some way you could use the mean value theorem!
f(c)= [f(6)-f(2)]/4
But I wouldn't have a clue where to go from there
2. Find the primitives of the functions
secxtanx
so I sed that u=secx and that du=secxtanx
So does this mean that the answer will just be equal to one?
The last one is just hard in the fact that I am unsure of wat u should be equal to...
integral x^6lnx(dx)
This problem is actually relatively simple, you're probably just overanalyzing it.
First, let's assume f(2) = 0. Since 1<=f'(x)<=3 for all x then the maximum change over the interval 2 to 6 is M*dx where M is the maximum value of the derivative of the function and dx is the change in x, in this case (6-2) or 4. So, the maximum difference between f(6) and f(2) is 12. If we analyze the minimum difference in the same way using the minimum value of the derivative, we arrive at 4. Therefore, the difference in the values of f(2) and f(6) must be between 4 and 12.
The second one is also simple, secx*tanx just happens to be the derivative of secx.
The last one is a simple integration by parts. Let x^6 = dv and ln(x)dx = u.
==> Integral(x^6*ln(x) dx) = uv - Integral(v*du) -- Integral(x^6*ln(x) dx) = ln(x)*(x^7)/7 - Integral(x^6/7 dx)
Or -- ln(x)*x^7/7 - x^7/49
2. [tex]\int \sec x \tan x \; dx = \sec x + C[/tex]
yeah I kinda get that... little bit confusing in some ways... y is it that u can just assume that f(2)=0... I get how u get the answers 4 and 12 from there then!
qu 2 yeah whoops that's wat I meant... I don't know y I sed it was equal to one!
Well it doesn't matter what initial value we choose for f(2) since the change of the function over a given interval is bounded by the definition of the derivative given in the problem. I could have chosen 9,042 and I still would have gotten f(6) at max is 9,054 and at minimum 9,046. Reread my original post very carefully and think about how differentials work and it should become pretty clear what I'm saying.
cool thanks... so its just easier to choose f(2)=0!
Thanks agen!
any suggestions for part 3... I know u need to integrate by parts... any pointers would be greatly appreciated
Taryn, for your last problem:
[tex]\int x^6 \ln x dx[/tex]
Let [tex]u = \ln x[/tex] and let [tex]dv = x^6 dx[/tex]. It follows from there that: [tex]du = \frac{dx}{x}[/tex] and that [tex]v = \frac{x^7}{7}[/tex].
It's all integration by parts from there:
[tex]\int u dv = uv - \int v du[/tex]
yeah okay wat I also did was letting u=x^7, du=7x^6 which is du/7=x^6
Then I got int 1/7(lnu^1/7)du
Then I used log laws and so I then had 1/49 int (lnu)(du)
I ended up gettin the answer (x^7lnx)/7 - (x^7)/49 + C
Is this rite?
Thats cool anyhow I know I did... checked it using your way! Thanks for your time!
