What Is the Correct Radial Acceleration for a Spinning Wheel?
The radial acceleration of a wheel with a radius of 0.2 m and a constant angular acceleration of α = 3.00 rad/s² is not constant and changes over time. The initial calculation of radial acceleration as 1.2 m/s² is based on the assumption that the wheel starts from rest and rotates through an angular distance of 1 radian, which was not specified in the problem statement. The book's value of 15.1 m/s² is likely derived from a different context or additional information not provided in the original question.
  • Understanding of angular acceleration and its effects on radial acceleration
  • Familiarity with the equations of motion for rotational dynamics
  • Knowledge of the relationship between linear and angular quantities
  • Basic grasp of kinematics in circular motion
  • Study the concept of variable radial acceleration in rotating systems
  • Learn how to apply the equations of motion for rotational dynamics in different scenarios
  • Explore the relationship between tangential and radial acceleration in circular motion
  • Investigate the implications of initial conditions on the calculations of angular motion
Students studying physics, particularly those focusing on rotational dynamics, as well as educators looking to clarify concepts related to angular acceleration and radial motion.
student34
A wheel with a radius of 0.2 m has a constant angular acceleration of α = 3.00 rad/s^2. Find the radial acceleration.
arad = ω^2*r
ω^2 = ωo^2 + 2*α(θ - θo) → ω = √(2*α*θ)
ω = √6 rad/s → a rad = 6*0.2 m/s^2 = 1.2 m/s^2
The book has 15.1 m/s^2. Is the book wrong?
arad = ω^2*r
Are you leaving something out of the problem statement?
With a constant angular acceleration, the radial acceleration is not constant. It will change with time.
In your attempted solution, you found the radial acceleration assuming that the wheel starts from rest, and after the wheel rotated an angular distance of 1 rad. Yet none of that was given in the problem statement.
Is something missing?
[Edit: the tangential acceleration will be constant though. But that's not 15.1 m/s2 either.]
Thank-you so much. I left out a bunch of stuff because I didn't think that it was relevant - lesson learned on tweaking questions too.
