How to Calculate the Radii of Two Circles Passing Through a Common Point?
  • Thread starter Thread starter Lifeforbetter
    Circles Radius
The discussion focuses on calculating the radii (r1 and r2) of two circles that pass through the common points (1,3) and (2,4) while also touching the y-axis. The circles' centers are determined by the relationship between their radius and the line equation y = mx + c. The formula used to derive the circles' equations is (x - R)^2 + (y - (mR + c))^2 = R^2, where R represents the radius. The slope (m) and y-intercept (c) are calculated as m = -1 and c = 5, leading to the radii values of r1 = 1 and r2 = 5.
  • Understanding of circle equations in Cartesian coordinates
  • Familiarity with linear equations (y = mx + c)
  • Knowledge of quadratic equations and their solutions
  • Basic geometry concepts related to tangents and circles
  • Study the derivation of circle equations from given points
  • Learn about the relationship between radius and tangent lines in circles
  • Explore quadratic equation solving techniques
  • Investigate graphical methods for visualizing circle properties
Mathematicians, geometry enthusiasts, students studying coordinate geometry, and anyone interested in solving problems involving circles and their properties.
Lifeforbetter
Two circles go through 2 points (1,3) (2,4)
Both circle touches y-axis. Find r1*r2
The mutiple of the radius of both circle
d = ##\sqrt{(x2^2-x1^2) (y2^2 - y1^2) }##
Middle point of (1,3)(2,4) is (1.5, 3.5)
r1 to r2 passing through (1.5, 3.5)
I cannot grasp on what should i do to find r1 and r2 from the line
Without graph*
Why don't you take the known information and put it on a graph. It's a start.
Without graph it should be
If the center of a circle of radius R is on the line y = mx + c and the circle touches the y-axis, then the equation of that circle must be <br /> (x - R)^2 + (y - (mR + c))^2 = R^2. If you know (x,y) (a point on the circle) and m and c then this is a quadratic you can solve to find R.
Here you know two points on the circle, (x_1,y_1) = (1,3) and (x_2,y_2) = (2,4). There are at least two ways of using this information to find m and c.
Who will know if you made a sketch for yourself? You can see the problem better from a graph. Solution without graph means that you can not read the results from the graph.
Both circles go through both points P1(1;3) and P2(2;4). And both circles touch the y axis. The centers of the circles are O1(x1;y1) and O2(x2;y2), there radii are r1, r2. See the "forbidden" graph (not in scale).
246569
How is the x position of the center of a circle related to the radius if the circle touches the y axis?
(The y-axis is tangent to the circle, the radius drawn to the tangent point is perpendicular to the tangent line.)
https://www.physicsforums.com/attachments/246567
If a1, b1 were the center point of circle 1. Then a1 = r1, then b1 = mr1 + c
Just what @pasmith says right?
The graph does help too.
y =mx + c
You mean the line go through middle point between P1 and P2? Which also go through r1 and r2 right?
That's m = -1 c = 5
Plug into
Either using (1,3) or (2,4)
Give me r = 1 or r = 5 right?
Yes.
  • · Replies 62 ·
10K
  • · Replies 48 ·
