Find the residues of the function
  • Thread starter Thread starter DanniHuang
    Function
The discussion focuses on finding the residues of the function f(z)=1/sin(z) at specific points: z=0, z=π/2, and z=π. The residue at z=0 is calculated as 1, while at z=π/2, it is determined to be 0. For z=π, the residue is more complex, and participants suggest using series expansion or L'Hopital's rule to evaluate the limit. The limit can be rewritten in terms of z-π to simplify the calculation. Ultimately, the residue at z=π is found to be -1 through proper evaluation techniques.
DanniHuang
f(z)=\frac{1}{sin(z)} at z=0, \frac{∏}{2}, ∏
Since the function has a simple pole at z=0
I used: Res(f,0)=lim_{z->0}(z-0)\cdot\frac{1}{sin(z)}=1. This means the residue of the function at z=0 is 1.
And Res(f,\frac{∏}{2})=lim_{z->∏/2}(z-\frac{∏}{2})\cdot\frac{1}{sin(z)}=0. This means the residue of the function at z=\frac{∏}{2} is 0.
However I think this method can not be applied on solving z=∏. How can I work it out?
Try expanding sin z in a series about ##z=\pi##. Or, better yet, use ##\sin z = \sin[(z-\pi)+\pi]##. The basic idea is to get everything in terms of ##z-\pi##.
If I turn everything into z-∏, do we need to use the same method as I used to work out z=0 and z=\frac{∏}{2}?
But how? Turn the limit to z-∏→0?
Because I used computer to work out the answer of z=∏ which is -1. But I still cannot get this answer by myself.
You find the residue by evaluating the limit
$$\lim_{z \to \pi}\ (z-\pi)\frac{1}{\sin z}.$$ Rewriting the limit in terms of ##z-\pi## is simply to make the evaluation easier. I just realized you could simply apply L'Hopital's rule to do that and avoid unnecessary complications. If you had a more complicated function, however, writing things in terms of ##z-\pi## is often less work than using L'Hopital's rule.
But say you did it with using the trig identity anyway. You should end up with
$$\lim_{z\to\pi} \frac{z-\pi}{-\sin(z-\pi)}.$$ You might already recognize that limit, but it not, use the substitution ##w=z-\pi## to turn it into one you should recognize.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
