Find the Sum of this Alternating Series
7 replies · 3K views
RJLiberator
Find the sum of
starts at 0 to infinity ∑ (cos(k*pi))/pi^k
First, I determined that it does, indeed, converge with the alternating series test.
Second, I found the answer to be pi/(1+pi) via wolfram alpha.
But I am at a loss on how to find the answer here.
This is a geometric series, so I am trying to find the r value. If I can do that, then I can use the trick of first term/(1-r)
Correct?
RJLiberator said:
Find the sum of
Correct?
It might be helpful to write the series without the cosine factor. All it contributes is +/- 1 each time.
RJLiberator said:
Find the sum of
Correct?
Why don't you just divide the ##k+1## term by the ##k## term to get ##r##?
So, with cos(k*pi) out, that would leave 1/pi^k. Therefore 1/pi^k = r? Hm.
k+1 term? Ok, let me try what I think you are saying:
k+1 term = value of 1, so k=1 and therefore cos(1pi)/pi^1 = -1/pi and the original k =0 term = cos(0pi)/pi^0 = 1. So, (-1/pi)/1 = -1/pi.
Hm, so if r = -1/pi then we can plug that into the first term/(1-r) equation, let's see:
First term = 1
(1-(-1/pi) = 1+1/pi
1/(1+1/pi)
If you multiple everything by pi, to simplify you get the answer of pi/pi+1 which is the correct answer.
Why did this work? Is there a trick I am not thinking of?
Thank you all. It seems I may have made a mechanical error with Mark44's suggestion. LcKurtz, do you know the definition/term of what you suggested so i can research it?
No it's not. ##\frac{\pi}{\pi} + 1 = 2##.
I'm being picky, but you need parentheses like you used in your first post here. IOW, like this: π/(π + 1).
## \cos k \pi =(-1)^k ## so you would have ##\sum_k \left(\frac{-1}{\pi}\right)^k ##
Mark44's suggestion should have led you to the same conclusion for r.
RJLiberator said:
So, with cos(k*pi) out, that would leave 1/pi^k. Therefore 1/pi^k = r? Hm.k+1 term? Ok, let me try what I think you are saying:
First term = 1
(1-(-1/pi) = 1+1/pi
1/(1+1/pi)
A geometric series looks like $$
\sum_{k=0}^\infty ar^k$$where ##r## is the common ratio. The ##k+1## term is ##ar^{k+1}## and the ##k## term is ##ar^k##. When you divide them you get the common ratio ##r##, no matter what ##k## is. What you did is divide the ##k=1## term by the ##k=0## term. That doesn't tell you anything unless you already know it is a geometric series. What you did gave you the correct ratio because it is in fact a geometric series, but the correct way to get the ratio and show it is a geometric series is divide the ##k+1## term by the ##k## term and observe you always get the same answer.
Excellent analysis, friends. I appreciate the words. Quite frankly, I am getting addicted to this series math.
