Find the value of k in the equation
  • Thread starter Thread starter shivam01anand
    Value
The problem involves finding the value of k in a quadratic equation where one root is the square of the other. The equation given is x^2 - x + k = 0.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationships between the roots and coefficients of the quadratic equation, exploring the implications of the roots being p and p^2. There are attempts to express the sum and product of the roots in terms of k, with some questioning the complexity of cubing p. Others suggest alternative methods to simplify the calculations.
The discussion has evolved with participants offering various approaches to derive k, including algebraic manipulations and the use of relationships between roots. Some participants have indicated potential simplifications, while others are still clarifying steps and exploring different interpretations of the problem.
There is mention of avoiding tedious calculations and the possibility of multiple legitimate values for k, indicating some ambiguity in the problem's setup or constraints.
shivam01anand
If the quadratic equations has 2 roots one of which is the square of the other find the value of k
x^2-x+k=0
let p and p^2 be the roots..
sum of roots= p(p+1)=1
product= p^3=k
then solving for p[quadratic] and then substituting into p^3=k
but the cubing part of p is rather tedious and not yielding the desired answer!
Where am i wrong
x^2-x+k=0
product= p^3=k
Where am i wrong
Are you familiar with these relationships?;
α + β = -b/a
αβ = c/a
Where α and β are the roots of the quadratic and a, b, c correspond to the coefficients (ax^2 + bx + c)
α + β = -b/a
αβ = c/a
That's what was used in the OP.
Please post your answer and the given answer.
There is a better way than cubing p. Use the two equations you have to eliminate the higher powers of p successively.
Right you are.
I missed that on account of both roots using p.
hmm okay a better way.
p^3=k
p^3-1=k-1
(p-1)(p^2+1+p)=k-1
(-P^2)(-2)=k-1
so that reduces p^3 to p^2 alright :D
have i cracked the quest for the simpler way?
It seems to me that simplest is
[tex](x- p)(x- p^2)= x^2- x+ k[/tex]
[tex]x^2- (p+ p^2)x+ p^3= x^2- x+ k[/tex]
So [itex]k= p^3[/itex] and [itex]p+ p^2= 1[/itex]
Use [itex]p+ p^2= 1[/itex] to determine p and then [itex]k= p^3[/itex] to determine k.
hey did we not get that directly from sum of roots and product of roots.
the question was whether you could avoid doing the cubing part..
thanksss
thanksss
Hi Shivam!
You have ##p^3=k##. Rewrite it as ##p^3-1=k-1##. Does that give you a hint? ;)
EDIT: Okay, I see you have done this.
shivam said:
(p-1)(p^2+1+p)=k-1
Good so far but I don't understand what you did next. What is the value of ##p^2+p+1##?
Pranav-Arora said:
Hi Shivam!
write that as -2 :D
shivam01anand said:
write that as -2 :D
It is not -2, check again!
Okay, +2 then!
shivam01anand said:
Okay, +2 then!
Yes, so have you solved the problem?
yes that's why i stopped commenting
;p
;p
p^3=k
p^3-1=k-1
(p-1)(p^2+1+p)=k-1
(-P^2)(-2)=k-1
Fwiw, what I had in mind was:
##p^2=1-p##
##p^3=p-p^2=p - (1-p)##
##k = p^3 = 2p-1##
so in the end there are two legitimate values of k, is that correct ?
##p^2=1-p##
##k = p^3 = 2p-1##
Haa this looks just like the reducing in matrices determints. using properties.
Will surely keep this "trick" in mind
You can also start with the quadratic formula.
[tex]x_{1,2}=\frac{1\pm\sqrt{1-4k}}{2}[/tex]
x1=x22---> [tex]\frac{1+\sqrt{1-4k}}{2}=\left(\frac{1-\sqrt{1-4k}}{2}\right)^2[/tex]
Expanding, simplifying leads to [itex]\sqrt{1-4k}=-k[/itex], that means k<0.
k=-2-√5.
The roots are 0.5(√5+3 )and -0.5(√5+1).
ehild
  • · Replies 22 ·
  • · Replies 20 ·
