Find the value of k in the equation
  • Thread starter Thread starter shivam01anand
    Value
The discussion revolves around finding the value of k in the quadratic equation x^2 - x + k = 0, given that one root is the square of the other. The roots are defined as p and p^2, leading to the equations p + p^2 = 1 and p^3 = k. Participants suggest avoiding tedious cubing by manipulating the equations to simplify the problem, ultimately leading to k = 2p - 1. The conversation highlights the importance of using relationships between the roots and coefficients to derive k without extensive calculations. The final consensus indicates that there are two legitimate values for k based on the derived equations.
shivam01anand
If the quadratic equations has 2 roots one of which is the square of the other find the value of k
x^2-x+k=0
let p and p^2 be the roots..
sum of roots= p(p+1)=1
product= p^3=k
then solving for p[quadratic] and then substituting into p^3=k
but the cubing part of p is rather tedious and not yielding the desired answer!
Where am i wrong
x^2-x+k=0
product= p^3=k
Where am i wrong
Are you familiar with these relationships?;
α + β = -b/a
αβ = c/a
Where α and β are the roots of the quadratic and a, b, c correspond to the coefficients (ax^2 + bx + c)
α + β = -b/a
αβ = c/a
That's what was used in the OP.
Please post your answer and the given answer.
There is a better way than cubing p. Use the two equations you have to eliminate the higher powers of p successively.
Right you are.
I missed that on account of both roots using p.
hmm okay a better way.
p^3=k
p^3-1=k-1
(p-1)(p^2+1+p)=k-1
(-P^2)(-2)=k-1
so that reduces p^3 to p^2 alright :D
have i cracked the quest for the simpler way?
It seems to me that simplest is
(x- p)(x- p^2)= x^2- x+ k
x^2- (p+ p^2)x+ p^3= x^2- x+ k
So k= p^3 and p+ p^2= 1
Use p+ p^2= 1 to determine p and then k= p^3 to determine k.
hey did we not get that directly from sum of roots and product of roots.
the question was whether you could avoid doing the cubing part..
thanksss
thanksss
Hi Shivam!
You have ##p^3=k##. Rewrite it as ##p^3-1=k-1##. Does that give you a hint? ;)
EDIT: Okay, I see you have done this.
shivam said:
(p-1)(p^2+1+p)=k-1
Good so far but I don't understand what you did next. What is the value of ##p^2+p+1##?
Pranav-Arora said:
Hi Shivam!
write that as -2 :D
shivam01anand said:
write that as -2 :D
It is not -2, check again!
Okay, +2 then!
shivam01anand said:
Okay, +2 then!
Yes, so have you solved the problem?
yes that's why i stopped commenting
;p
;p
p^3=k
p^3-1=k-1
(p-1)(p^2+1+p)=k-1
(-P^2)(-2)=k-1
Fwiw, what I had in mind was:
##p^2=1-p##
##p^3=p-p^2=p - (1-p)##
##k = p^3 = 2p-1##
so in the end there are two legitimate values of k, is that correct ?
##p^2=1-p##
##k = p^3 = 2p-1##
Haa this looks just like the reducing in matrices determints. using properties.
Will surely keep this "trick" in mind
You can also start with the quadratic formula.
x_{1,2}=\frac{1\pm\sqrt{1-4k}}{2}
x1=x22---> \frac{1+\sqrt{1-4k}}{2}=\left(\frac{1-\sqrt{1-4k}}{2}\right)^2
Expanding, simplifying leads to \sqrt{1-4k}=-k, that means k<0.
k=-2-√5.
The roots are 0.5(√5+3 )and -0.5(√5+1).
ehild
