How Do You Solve for a, b, and c in Polynomial Equations?
  • Thread starter Thread starter aisha
The discussion revolves around finding the coefficients a, b, and c in the polynomial equation x^3 - 1 = (x - 1)(ax^2 + bx + c). Participants express confusion about the problem and explore various methods to approach it, including polynomial division and coefficient comparison.
  • Exploratory, Problem interpretation, Assumption checking
  • Some participants suggest dividing x^3 - 1 by x - 1, while others propose multiplying out the right-hand side and comparing coefficients. There are also mentions of substituting specific values of x to generate equations for a, b, and c.
Several methods have been proposed, and some participants have shared their attempts at solving the problem. There is a mix of interpretations regarding the relationships between a, b, and c, with no clear consensus on the correct values yet.
Participants note the importance of understanding polynomial factorization and the implications of assuming certain values for a, b, and c based on their methods. There is also mention of potential errors in reasoning regarding the cancellation of terms.
aisha
I looked at this question and said WHAT? i don't know what its talking about can someone please help me out, I don't have a clue as to what to do, or where to start. :cry:
For x^3-1=(x-1)(ax^2+bx+c) find the values of a, b, and c
Try dividing x^3 -1 by x - 1.
Do you know how to do that?
Or he could multiply out the RHS and set both sides equal to each other.
Or he could plug in values of x to generate a system of equations.
Many polynomials can be factored into products of smaller polynomials.
E.g -
(x^2 - 1) = (x+1)(x-1)
This is known as factorisation of polynomials.
x^3-1 can be factored in a similar way.
Now,
What does this mean?
This means that x^3 - 1 can be factored into two polynomials (x-1) and (ax^2+bx+c).
You are supposed to find the coefficients of the second polynomial.
Ways to do it?
1> Factorise x^3-1 manually and see what u get?
Suppose u get,
x^3-1 = (x-1)(px^2+qx+r)
then a = p,b = q and c = r.
2> Now if x^3-1=(x-1)(ax^2+bx+c)
then (x^3-1)/(x-1) = (ax^2+bx+c)
That means u can get (ax^2+bx+c) by dividing x^3-1 by x-1.
3> Multiply RHS. That is multiply (x-1) with (ax^2+bx+c) . Then compare the coefficients of this with x^3 - 1 so that u can determine a,b and c
4> Note that,
is true for all x
So substitute x = 0 and u will note that u can get c
sub in x = -1 and u will get an equation in terms of a and b
sub in x = 2 and u will again get an equation in terms of a and b
solve them simultaneously to find a and b.
-- AI
Ya, this question is rather simple.
Three simple method:
1. Long division. Don't forget to wite down 0x^2 and 0x
2.Identity. Comparing coefficient. Expand the given function.
Compare the term to x^3-1
3.The most common one. It is learned in Grade K10 I think.
x^3-1=(x-1)(x^2+x+1)
This is what I got:
ax^2+bx+c=\frac{x^3-1}{x-1}=x^2
ax^2+bx+c=x^2
a=\frac{x^2-bx-c}{x^2}
The x^2 get canceled out and I got:
a=bx-c
*NOTE: I might be wrong
Yeah, Raza you are... wrong that is.
a=\frac{x^2-bx-c}{x^2} does not cancel out to get a=bx-c
Plus, you say that ax^2+bx+c=x^2. If this is true for all (since a,b and c are constants) that would mean that either a,b and c are all = 0, (which the aren't) or that a = 1* and b and c = 0 (which, they don't)
I think I've got the answer
Hi, thanks for all ur help I think I've got it tell me if u think I am wrong.
the question was for X^3-1=(X-1)(ax^2+bx+c)
what are the values of a, b and c
well I brought x-1 to the LHS and divided x^3-1 by x-1 I used long division and i got an answer of x^2+x+1 with no remainder I made this equal to ax^2+bx+c and I think a=1 b=1 and c=1 ? I'm not sure
Sounds right to me.
  • · Replies 19 ·
  • · Replies 48 ·
  • · Replies 18 ·
