Find the voltage across a capacitor in a LRC circuit
7 replies · 4K views
splatcat
thank you for any help in advance.
The question is; In a series LRC circuit, find an equation that shows the ratio of Voltage out [the voltage measured over the capacitor] over the voltage in from an A/C source as a function of L R C and omega
Starting with this equation:
Vs = sqrt(VR2 + (VL - VC)2)
The attempt at a solution, I have no idea how close/right this is as I do not have the solutions,
Vout / Vs = 1/(C*omega*sqrt(R2 + (omega*L - 1/C*omega)2))
[/b]
Any help/ advice would be greatly appreciated :) thanks
Stu
[/b]
Stu
Welcome to the PF.
Do you know how to express the complex impedance of each element in this circuit?
thank you for your response, your question helped direct my reading. I think I have a better idea of what I am doing now. I have come to a new solution. Is it any closer?
I have some understanding of complex impedance now.
w = omega
Vout/Vin = (R + iLw) / (R + i(wL + 1/wC) )
Vout / Vs = 1/(C*omega*sqrt(R2 + (omega*L - 1/C*omega)2))Stu
That is the correct solution if the ratio of the magnitudes was the question.
ehild
w = omega
Wrong. The voltage across the capacitor was the question. And the complex impedance of the whole circuit is R + i(wL - 1/wC).
ehild
(Voltage amplitudes was the quesion :) ) Sorry I did mean to put a minus sign in there instead of a + sign. However does the system not work like a potential divider? Only resistances are impedances?
Stu
Stu
Yes, but you need add up the square of the real and imaginary parts, and then take the square root to get the resultant impedance, as you did in your first post.
ehild
Thank you very much for your help. I am pretty sure I understand where I have gone wrong :)
