Calculating Volume of Solid using Disk/Washer Method
  • Thread starter Thread starter Emethyst
    Solid Volume
The discussion focuses on calculating the volume of a solid generated by rotating the region enclosed by the curves y=sqrt(x+1), y=2x/3, and the x-axis about the x-axis using the disk/washer method. The user initially attempted to solve the integral V=pi∫(x+1-(4x^2/9))dx over the interval [3,-1], leading to an incorrect volume result. A key insight provided by another participant is to break the problem into two integrals, as the lower boundary changes from y=2/3x to the x-axis within the region of interest.
  • Understanding of the Disk/Washer Method for volume calculation
  • Ability to find points of intersection between curves
  • Knowledge of definite integrals and their evaluation
  • Familiarity with plotting functions to visualize regions
  • Study the Disk/Washer Method in detail, focusing on its application in volume calculations
  • Learn how to find points of intersection for nonlinear functions
  • Practice breaking complex volume problems into multiple integrals
  • Explore graphical tools for plotting functions and visualizing regions of integration
Students studying calculus, particularly those focusing on volume calculations using the disk/washer method, as well as educators looking for examples of problem-solving strategies in integral calculus.
Emethyst
Find the volume of the solid generated by rotating the region enclosed by y=sqrt(x+1), y=2x/3, and the x-axis about the x-axis
Disk/washer method, shell method
This question seemed easy enough, as I found the points of intersection for the 2 functions (these points being -1 and 3), then plugged each of these functions into the disk/washer method equation and tried to solve over [3,-1]. This did not get me very far, for I ended up with an answer higher than the 4pi I should have gained. This is the way I set up the equation:
V=pi\int(x+1-(4x^2/9))dx (I already applied the squares to the functions inside the integral). I am wondering if I made a mistake setting this question up, or if I made a mistake with the closed interval I used. If anyone can point me in the right direction for this question it would be greatly appreciated, thanks in advance.
Hi. You need to plot it carefully and look at it: the lower boundary of the region is the function y=2/3x in one part of the region, but is the x-axis in the second part of the region. So . . . break it up into two integrals.
  • · Replies 16 ·
  • · Replies 17 ·
