xiaobai5883
- 22
Find the volume of the solid bouded by the hyperboloid.
(x^2/a^2)+(y^2/b^2)-(z^2/c^2)=1
and the planes z=0 an z=h, h>0.
The discussion focuses on calculating the volume of a hyperboloid defined by the equation (x^2/a^2) + (y^2/b^2) - (z^2/c^2) = 1, bounded by the planes z=0 and z=h. Participants suggest using the disk method or coin theory to integrate the area of elliptical cross-sections, which vary with z. The volume can be computed by integrating the area function A(z) from z=0 to z=h, where A(z) represents the area of the ellipse at height z. The conversation also references Green's and Gauss' theorems as foundational theories linking integration of line equations to area and volume calculations.
PREREQUISITESStudents studying calculus, mathematicians interested in solid geometry, and educators teaching volume integration methods.
HallsofIvy said:?? Not an easy integration but certainly a straightforward problem. Have you simply not tried? If you have tried, what have you tried?
Cyosis said:The cross sections of this hyperboloid parallel to the x-y plane are ellipses. So instead of circular slices where you integrate over pi f(z)^2 you now have to use the formula for the area of an ellipse. It is given by pi a b, with a and b the semi major and -minor axis respectively. You can express a and b as a function of z.
HallsofIvy said:One way to do this is the way Cyosis recommends: for a given z, the section of the the hyperboloid is given by x^2/a^2+ y^2/b^2= 1+ z^2/c^2. Integrate the area of that, as a function of z, with respect to z.
Another way is see that, for any point (x,y) in the xy-plane, z= \pm\c\sqrt{1- x^2- y^2} so you can integrate the difference between those (the height of a thin rectangle) over the ellipse x^2/a^2+ y^2/b^2= 1.
Cyosis said:For any solid, if you can find a function of the area of the cross section perpendicular to the direction you are integrating in as a function of that direction, then you can find its volume by simply integrating over the height coordinate (mouthful). Imagine a cylinder centered around the z-axis. The volume of this cylinder is simply the area of the base times the height. Now let's cut this cylinder into a lot of small slices each with height dh. The volume of each of these slices is the area*dh. The volume of the entire cylinder can be found by adding all these thin slices together. This is what integrating basically does.
In the cylinders case the area of every slice was constant and therefore independent of the integration variable. In your case however if you slice the hyperboloid up every slice will have a semi major/minor axis that depends on z. Let's call this function A(z), then the volume of the hyperboloid is simply adding all the slices between z=0 and z=h together, \int_0^h A(z)dz. Now it is up to you to find A(z). The easiest way to envision how you do that is to draw a picture of the x-z plane and the y-z plane.
