Finding a basis for the span of 4 vectors.
To find a basis for the span of the four given vectors, it is determined that the vectors are linearly dependent, as indicated by a zero determinant. The Gauss-Jordan elimination method is suggested to identify the linear relationships among the vectors, revealing that two of the original vectors can be discarded. The final reduced matrix indicates that the first two vectors, V1 and V2, form a basis for the subspace spanned by the original vectors. This conclusion is reached by demonstrating that the other vectors can be expressed as linear combinations of V1 and V2, confirming their independence. Thus, V1 and V2 serve as the basis for the span of the four vectors.
M55ikael
Hi!
I can't for the life of me figure out how to do this. I need to find the basis for the span of these four vectors:
V1= 3, 1, -2, -4
V2 = -5, -3, 5, 9
V3 = 5, -1, 0, -2
V4 = -1, 5 -6 -8
2. The attempt at a solution
I've figured out that the determinant is zero, so in its current form it's definitely not a basis. At least one of the vectors are obsolete, and they don't span R4. I was going to take away a vector at random and see if the remaining vectors were linearly dependent or not, but I'm not sure how to prove that a non square matrix is linearly independent.
Example: Say I take away one vector and use gauss-jordan elimination on the matrix comprised of the remaining vectors. I would eventually end up with all the constants equal to zero, or one or more rows of zeros. But if I ended up with an identity matrix, it wouldn't actually prove that the ONLY solution was that alle the constants are zero, would it?
This is my first post , so please be kind ;-) Thanks for helping me out!
EDIT: Sorry, this might have been better suited for the physics sub-forum.
Have you tried the gram-schmidt process? it'll eliminate linearly independent vectors by itself.
Because they are dependent, there exist numbers, a, b, c, and d, not all 0, such that
a(3, 1, -2, -4)+ b(-5, -3, 5, 9)+ c(5, -1, 0, -2)+ d(-1, 5, -6, -8)= (0, 0, 0, 0).
That is the same as saying 3a- 5b+ 5c- d= 0, a- 3b- c+ 5d= 0, -2a+ 5b- 6d= 0, and -4a+ 9b- 2c- 8d= 0. Solve for a, b, d, and d (there will be an infinite number of solutions). You can drop a vector for which the coefficient is non-zero. Then check the remaining three to see if they are independent. If not, repeat!
Thanks! It seems the problem was that I don't know how to solve solve equations with indefinite amounts of solutions.
When using Gauss-Jordan elimination I found the following:
a = 7d
b = 4d
c = 0
d = b/4
Am I supposed know that the constants (ie. a,b,c,d) are indefinite when they are dependent on each other in this manner?
I choose a=1 and find that the equations do add up, but the fact that I had to do it illustrates that I'm not used to this kind of thinking.
Another way to find a basis for the subspace spanned by the given vectors is to form a matrix with the vectors as columns in the matrix.
After forming the matrix, row-reduce it. If the vectors are linearly independent, the matrix will have no rows that are all zero. If the vectors are linearly dependent, one or more rows in the reduced matrix will consist entirely of zeros. That's what happens in this case: two of the rows have entries that are all zero.
Once the matrix is completely reduced, you can write the system of equations that the reduced matrix represents, and get a basis from the system.
For this problem, the reduced matrix is
\left[ \begin{array}{cccc}1&0&5&-7\\0&1&2&-4\\0&0&0&0\\0&0&0&0\end{array}\right].
The system that this matrix represents is
c_1=-5c_3+7c_4
c_2=-2c_3+4c_4
c_3=1c_3 + 0c_4
c_4=0c_3 + 1c_4
The two basis vectors are the vectors whose entries are the coefficients of c3 and c4.
c_1=-5c_3+7c_4
c_2=-2c_3+4c_4
c_3=1c_3 + 0c_4
c_4=0c_3 + 1c_4
Thanks! English isn't my first language, so I didn't quite get the final sentence.
Does that mean that the basis would be:
\left[ \begin{array}{ccc}-5&7\\-2&4\\1&0\\0&1\end{array}\right].
What was your row-reduced matrix? I didn't get c=0.
Ignoring that for a moment, let's take your solution and (arbitrarily) set d=1. Then a=7 and b=4. Plugging this back into your original equation, you have
7v1+4v2+v4=0
or
v4=-7v1-4v2
In other words, v4 can be written as a linear combination of v1 and v2, so you can toss it.
\left[ \begin{array}{cc}-5&7\\-2&4\\1&0\\0&1\end{array}\right].
Sort of. A basis would be those two column vectors (not a 4 x 2 matrix).
7v1+4v2+v4=0
or
v4=-7v1-4v2
Yeah I followed HallsofIvy's suggestion and tossed one of the non-zero vectors, in this case v1. Then I did the elimination again with only three vectors and arrived at this system:
a= 6/5c
b= 7/5 c
c= 5/6a
Then I tossed v2, did the elimination and found that both constants had to be zero.
But the initial elimination was probably flawed as I got c = 0, and the whole thing was just a fluke. However, I do believe the method is valid.
Yup, I just don't know how to write things properly in this forum yet. Is there a tutorial btw?
Thanks for helping out everybody.
You did pretty well. Writing matrices in LaTeX is one of the trickier things to do (in my limited experience at it).
Here's a page with several links: https://www.physicsforums.com/showthread.php?t=386951
c_1=-5c_3+7c_4
c_2=-2c_3+4c_4
c_3=1c_3 + 0c_4
c_4=0c_3 + 1c_4
Actually, Mark made a slight error here. Those two vectors give you a basis of the null space of the matrix. You're actually looking for a basis of the column space of the matrix. You can identify which of the original vectors form such a basis by locating where the pivots are in the reduced matrix. In this case, they're in the first two columns, so v1 and v2 would be the basis you're looking for.
What's a pivot?
A pivot is the leading 1 in a row after the matrix has been reduced to row-echelon form.
Are there any proofs? It seems so simple I wonder why it's not mentioned in my book.
Khanacademy teaches the same method as Vela described here:
I was wondering though, if it's ok for the columns to have constants other than zero above the 1, meaning you would have a row-echelon matrix as opposed to a reduced row-echelon matrix. My logic tells me that the vectors would be linearly independent anyway, so I guess it's ok.
c_1=-5c_3+7c_4
c_2=-2c_3+4c_4
c_3=1c_3 + 0c_4
c_4=0c_3 + 1c_4
Vela is right. The two vectors I showed are a basis for the nullspace, which isn't what you're after.
However, the system of equations above (with the ci's) can be used to get basis vectors for the spanning set. In essence, the row reduction goes back to finding solutions to the equation c1v1 + c2v2 + c3v3 + c4v4 = 0, which is what HallsofIvy was saying back in post #3 or so. The vi's are the vectors we started with.
Since we ended up with a couple of rows of zeros in the row-reduced matrix, the four original vectors aren't linearly independent. Earlier, vela showed that two vectors would suffice to span the subspace spanned by the four given vectors.
If you look at the equations for ci that I gave, you can see that all four constants depend on c3 and/or c4. If you arbitrarily set c3 to 1 and c4 to 0, you can see that c1 = -5 and c2 = -2. This means that -5v1 -2v2 + 1v3 = 0, so you can solve for v3 as a linear combination of v1 and v2.
Now, if you set c3 to 0 and c4 to 1, you can see that c1 = 7 and c2 = 4. This means that 7v1 + 4v2 + 1v4 = 0, so you can solve for v4 as a linear combination of v1 and v2.
Since both v3 and v4 are linear combinations of the other two vectors, we can discard them, leaving us with v1 and v2. These vectors span the space spanned by all four vectors, and they are linearly independent (by inspection - neither is a multiple of the other), so they are a basis for the subset of R4 spanned by the original four vectors.
