Finding a Coefficient in an Expansion (n-j is negative?)
The discussion focuses on finding the coefficient of x8 in the expansion of (x2 - 3)7. The correct approach involves using the binomial theorem, specifically the formula (a + b)n = Σ (n choose j) aj b(n-j). Participants clarify that x should be treated as x2 and that n remains 7 while j must be 4 to avoid negative powers. The final coefficient is derived correctly by substituting these values into the binomial expansion.
  • Understanding of the binomial theorem
  • Familiarity with binomial coefficients (n choose j)
  • Basic algebraic manipulation of exponents
  • Experience with polynomial expansions
  • Study the binomial theorem in detail, focusing on its applications in polynomial expansions.
  • Learn about binomial coefficients and how to calculate (n choose j).
  • Practice problems involving coefficients in polynomial expansions, particularly with squared terms.
  • Explore the use of computational tools like Wolfram Alpha for verifying mathematical solutions.
Students studying algebra, particularly those tackling polynomial expansions and the binomial theorem, as well as educators looking for clarification on teaching these concepts.
rakeru
Find the coefficient of x8 in the expansion of (x2-3)7
This one:
(n n-j) an-jxj
Hi!
Well, I know that
x= x2
a= -3
n= 7
and apparently, j=8.
This is what confuses me. n-j is a negative number.. how would that even work?? My guess is that the x2 has to do with it somehow... I'm thinking because the x is squared, then n wouldn't be 7.
Please help!
I wrote this on wolfram alpha because I was like.. "is this possible or is it just a typo?" and it gave me an answer!
Thank you!
This one:
(n n-j) an-jxj
Hi!
Well, I know that
x= x2
a= -3
n= 7
Please help!
Thank you!
No, no. (a+b)^n=sum over j of (n j)a^j*b^(n-j). Put a=x^2 and b=(-3). You are likely getting confused because you are using the same symbol x for two different things. Saying x=x^2 is just silly.
Likes 1 person
Hmm well.. that's how my professor did it.
So after trying multiple times with different values for n and j, I got the right one. I ended up using n=7 and j=4. At first I tried n=14 and j=8. Nope. Then, I tried n=14 and j=4. Nope. Then, I tried n=7 and j=4! It worked... I'm still not so sure of why. I think the n is seven like normal.. but if I put 8 as j, then x will be to the power of 16. So I tried 4 and it worked..
Thanks.
rakeru, if I asked you to calculate the power of y4 in (y-3)7, do you see why this is the same as your original question?
In that case, j would be just four, right?
Of course it would. Same for your original problem if you separate the two uses of x.
Oh my god! Yes! I see!
Thank you!
I wonder why my teacher did it like that, though.
Thanks! :)
10K
