Finding a general soution to a differential equation
8 replies · 4K views · last reply
Rubik
How do I find a general solution to a differential equation when the answer is a constant?
The answer of what question ? Give an axample.
y = an arbitrary constant is the general solution to dy/dx = 0
Tell us what equation you are trying to solve, if you want more help.
y'' - 4y' = 4
z = y'
z' - 4z = 4
No difficulty to solve this ODE, thanks to classical method.
z = C* exp(4x) -1
C = constant
Then, the primitives of z(x) :
y = A*exp(4x) - x + B
B = constant ; A = C/4 = constant.
Wow thank you so much.. I was confusing myself and thinking it seemed a little too easy.
Also is this the method of undetermined coefficients?
Yes, it is. Since r= 0 is a solution to the characteristice equation [itex]e^{0x}= 1[/itex], a constant, is already a solution so you, instead of trying a constant to get the "4" on the right, you multiply by x and try y= Ax. y'= A, y''= 0 so the equation becomes
-4A= 4 and A= -1. That is where the "-x" in the solution came from.
I suppose that your question is about solving z' - 4z = 4
First, solve the homogeneous equation Z' - 4Z = 0
dZ/dx = 4Z
dZ/Z = 4 dx
ln(Z) = 4x +c
(c = constant)
Z = exp(4x+c)
Z = C*exp(4x)
C = exp(c) = constant
Second, find a particular solution of z' - 4z = 4
z = -1 is obiously a particular solution.
Third, add the pareticular solution to the solutions of the homogeneous equation :
z = Z+(-1)
z = C*exp(4x) -1
This is a well-known way to solve an EDO such as z' - 4z = 4
