Finding a matrix W such that W^t*AW = D (D is diagonal matrix)
3 replies · 2K views
zjohnson19
A = 000
010
101
Find Eigenvalues, its corresponding eigenvectors, and find a matrix W such that W^t*AW = D, where D is a diagnol matrix.(note that W^t represents the transpose of W)
Eigenvalues, Eigenvectors, diagnolization[/B]
Question 1 is to find eigenvalues. Since it is already a lower triangular matrix this was easy and I believe the eigenvalues are 1 and 0. The characteristic equation I got was (0-y)(1-y)(1-y).
Question 2 was to find the corresponding eigenvectors. if y1 = 1, then (A-1I) = -100
000
100
From that you get x1 = 0. x2 and x3 are free. So a basis for the eigenspace is (v1, v2) where
v1 = 0
v2 = 0
For y = 0, A -0 is just A. you get x2 = 0 and x1 = -x3 with x3 free. Therefore the corresponding eigenvector is
v = -1
Correct me if I'm wrong but I believe up to here I have done everything correct.
The final part of the question confuses me quite a bit . "find a matrix W such that W^t*AW = D, where D is a diagnol matrix."
I thought diagnolization is only possible if a matrix is invertible. Since A has 0 as an eigenvalue, it is not invertible. Did I get the eigenvectors wrong or is D not the diagnolization of A?
Edit: I cannot find a way to get the space formatting correct. Does anyone know how?
zjohnson19 said:
A = 000
010
101
000
100
v1 = 0
v2 = 0
v = -1
The zero vector is never considered as an eigenvector, so your v2 is incorrect. Not only that, you want the eigenvectors to form a basis (which is possible in the diagonalizable case), and the zero vector is never part of a basis.
My bad, I had that copied down wrong(I edited it now to fix it). I had v2 as (0 0 1), not (0 0 0). So a basis for the eigenspace corresponding to lambda = 0 would be
[0] [ 0]
|1| , | 0|
[0] [ 1]
one eigenvector would be
[0]
|1|
[1]
I've tried to diagnolize the matrix and I found an P and A that work(since AP = PD).
I got p from the bases of the eigenspaces.
p =
00-1
10 0
01 1
I chose D to be the eigenvalues in the diagnol positions corresponding with its bases in p
D=
100
010
000
AP=PD so this step should be fine.
I then was hoping this would work for the final answer and I could choose P as the answer. Unfortunately the transpose of P * AP does not equal this diagnol matrix.
Anyone know where to go from here?
