Finding Absolute Extrema on a Closed Interval
11 replies · 4K views
silverbomb20
FIND THE ABSOLUTE MINIMUM AND ABSOLUTE MAXIMUM OF:
f(x) = 9x + 1/x
on the interval [1,3]
I don't know how to get started!
hi silverbomb20 - any ideas or thoughts on what defines a maxima or minima?
i know i need to use the power rule to get it started, but i don't know how to apply it to the fraction..
derivative of x ^n is n * x^(n-1) right?
i know the 9x would go to just 9
but i am unsure about the fraction
first part sounds good
so we're stuck on
[tex]\frac{d}{dx} (\frac{1}{x})[/tex]
you could write it like below and use the power rule
[tex]\frac{d}{dx} (x^{-1})[/tex]
or you could try and do it from first principles...
okay so would it be 9 + -1x^-2 ?
im a history major having a lot of trouble with calculus...please help me
yes, that looks correct
so when does
[tex]9-\frac{1}{x^2} = 0[/tex] ?
in my mind...never.
f1(x) = 9 + -1x^-2
so i have to set it equal to zero right?
so 9 + -1x^-2=0
but that doesn't factor
Multiply both sides by x^2.
Before we get (more) bogged down with minutiae, let's look at the strategy. Extreme values of a function f will happen at values of x for which f'(x) is zero, or at endpoints of the interval of definition.
f'(x) represents a critical point which could be a maxima, minima or point of inflection, but you nee dto check to find which
as we are talking about absolute max & min we also need to check the boundaries of [1,3] ie the points x=1 and x=3
as for the local minima you're on your way
9 + -1x^-2=0
try first multiplying both sides of the equation by x^2
okay so that's going to give me 9x^2=x^2?
or does that -1x^-2 not cancel?
No. Try again.
