Finding acceleration from two force vectors
7 replies · 3K views · last reply
mischaoc
Two forces
F1 = -8.20i + 4.30j and
F2 = 7.10i + 4.60j
are acting on a mass of m = 6.90 kg. The forces are measured in Newtons. What is the magnitude of the object's acceleration?
i tried to add the vectors and using the f=ma to find acceleration but the answer is wrong.
please help
thnx
  • Graph of three vectors from the origin on a labelled x-y grid: F1 in blue pointing left and up, F2 in red pointing right and up, and their resultant F1+F2 in magenta pointing up, with a table of x-component, y-component, magnitude and direction for each.
Draw a picture!
Hi mischaoc! Welcome to PF! :smile:
It always helps to draw a diagram first (just roughly), to see what's going on.
Draw the i and j axes, and three lines with arrows on to represent the two forces and a guess as to the acceleration.
Do you know the relationship between those three lines?
Have you neglected to include the force of the mass acting downwards due to gravity? I know that is a mistake that my sister has made when completing similar problems.
nice diagram! and colour-coded … I'm impressed!
Hi mischaoc!
From the way you've drawn the diagram, it seems to me that you've worked out what the rule is. :smile:
What's worrying you?
Show us your working, and the right answer (actually, you should have done that originally).
(and ignore mike's sister - I always ignore mine! :smile:)
my work
i added the vectors and gor F3=-1.1i+8.9j
then i calculated the magnitude of
F3=[tex]\sqrt{(-1.1)^2+(8.9)^2}[/tex]=8.9 N
i found the angle [tex]\alpha[/tex]=tan-1 [tex]\frac{8.9}{-1.1}[/tex]
so [tex]\alpha[/tex]=97.5
using the F=ma formula:
8.9*cos(97.5)=6.9*a
a=-0.168
but it's wrong.
Aha! … now, that's not right, is it? :frown:
You see - that is why the forum rule is that you show what you've done!
Is it ok now? :smile:
mischaoc said:
it's F3=8.98 N
Actually, I make it 8.968 (or 8.97).
8.9*cos(97.5)=6.9*a
Why did you put the angle in?
(Are you thinking that j is vertical, and that somehow the weight is involved? That's not what the question says.)
You have the size and direction of the force.
So you divide by m to get the size and direction of the acceleration. That's all!
Don't make it more complicated! :smile:
