Finding angle and direction from a rotation matrix
8 replies · 3K views · last reply
breen155
Hey guys, I'm not sure if this bit is relevant but the first part of the question is... 'The diagram shows a triangle with vertices O, A(1,2) , B (0,2). The question I need help with is 'Each of the following matricies represents a rotation about the origin, Find the angle and direction of rotation in each case'
(1/2 -[tex]\sqrt{3}[/tex]/2)
([tex]\sqrt{3}[/tex]/2 1/2)
Imagine its one big set of brackets around the above matrix not 2 smaller ones :)
I'm also not sure whether these are of relivance but x' = ax + cy and y' = bx + dy
also I have the matrix
cos[tex]\theta[/tex] -sin[tex]\theta[/tex]
sin[tex]\theta[/tex] cos[tex]\theta[/tex]
I have been messing about with this for a while attemting to sub in co ordinates to the x' equations and y' equations but I feel I am getting nowhere. I would appreciate any help.
Thanks in advance guys
Breen155
[tex]\begin{pmatrix} a & -b \\ b & a \end{pmatrix} = \begin{pmatrix} cos(\theta) & -sin(\theta) \\ sin(\theta) & cos(\theta) \end{pmatrix}[/tex]
[tex]a = \frac{1}{2}[/tex]
[tex]b = \frac{\sqrt{3}}{2}[/tex]Can you use the definition of equality of matrices to get two equations for theta?
not too sure what you mean sorry I only started teaching this to myself this morning :S erm... is it costheta - sin theta = .5 and sintheta + costheta = sqt3/2 ?
I slipped up on my notation. I fixed my last post. Try to get the equations again because they aren't right. Remember, get them by using the definition of equality for matrices.
theta is 60 degrees but how do i tell the direction of rotation, clockwish or anticlockwise ? :) (thanks for the help so far btw)
Remember that a positive theta corresponds, by convention, to a counterclockwise rotation. If it were a clockwise rotation of 60 degrees, then theta would be -60 degrees. This is equivalent to a counterclockwise rotation of 300 degrees, and you see that the sine and cosine of 300 degrees is exactly equal to the sine and cosine of -60 degrees. Of course, this means the question is a bit vague, since you can change the direction of rotation just by changing the angle. If you have both a direction with a correct angle, however, it should be fine.
