Finding angle of billiard ball after collision
6 replies · 6K views · last reply
luffy3san
A billiard ball of mass 0.162 kg has a speed of 1.86 m/s and collides with the side of the billiard table at an angle of 51.8°. For this collision, the coefficient of restitution is 0.841. What is the angle relative to the side (in degrees) at which the ball moves away from the collision?
m = 0.162 kg
vi = 1.86 m/s
θ = 51.8°
CR = 0.841
CR = v/u
mvxi + mvyi = mv'xf + mv'yf
CR = v/u
0.841 = v / 1.86 m/s
v = 1.56 m/s
mvxi = mvxf
mvcosθ = mvcosθ'
1.86 * cos 51.8° = vxf
vxf = 1.15 m/s
cosθ' = vxf/v
cosθ' = 1.15/1.56
θ' = cos-1(1.15/1.56) = 42.5°
luffy3san said:
CR = v/u
v = 1.56 m/s
mvxi = mvxf
mvcosθ = mvcosα
I have a problem with these two. E.g. the second says θ = α and I don't believe the first one either!
Is momentum really conserved in the billiard ball? What about momentum transferred to the Earth via the pool table etc.?
M.E.'s out there, help?
vxf = 1.15 m/s
cosα = vxf/v
cosα = 1.15/1.56
α = cos-1(1.15/1.56) = 42.5°[/QUOTE]
vxf = 1.15 m/s
cosα = vxf/v
cosα = 1.15/1.56
Hmm not sure about the momentum transfer to the Earth etc. I checked a couple sites where they said momentum is conserved in the x direction in this situation.
Yeah, that makes sense. Momentum transfer to Earth should be only in the direction perpendicular to the table's side. Good point. Did you pick x as going along the side of the collision?
Yes, I think so. I chose the x-axis to be the side of the table. On a x-y coordinate, the ball travels from the 3rd quadrant, hits at the origin, and deflects towards the 4th quadrant. And, I chose the angles to be along the x axis. Don't know if that's the right way.
I think you are supposed to assume that the speed is reduced only in the direction perpendicular to the cushion.
AM
AM
Yeah, that's what I was assuming but i found out my mistake. I noticed that CR should've been CR = [itex]\vec{v}[/itex]sinθ' / [itex]\vec{u}[/itex]sinθ
Thanks rudeman and Andrew for the suggestions!
