Finding angles between vectors
  • Thread starter Thread starter adrimare
    Angles Vectors
The discussion revolves around finding angles between vectors, specifically in the context of a parallelogram formed by two vectors and the angle between two other vectors. The original poster presents two related questions involving vector OA = (3,2,-6) and OB = (-6,6,-2), as well as vectors OP = (3,4,5) and AE = (-3,4,5).
  • Mixed
  • The original poster attempts to apply the cosine law to find the angles but encounters confusion regarding the calculations, particularly for the first question. They express uncertainty about their results and seek clarification on the second question, indicating a desire to understand the application of the dot product.
Participants are actively engaging with the original poster's attempts, offering insights into the calculations and suggesting that the dot product could simplify the process. There is acknowledgment of a potential misunderstanding regarding calculator settings, which may have affected the results.
The original poster mentions a requirement to solve the second question without using the dot product, which may limit their approach to the problem.
adrimare
I have two related questions related because they both ask to find angles between vectors.
The first one says to determine the angles between the sides of a parallelogram determined by the vectors OA = (3,2,-6) and OB = (-6,6,-2).
The second one asks to determine the angle between OP and AE, where OP = (3,4,5) and AE = (-3,4,5).
For the first one, I tried to use the cosine law, but got 1.5 degrees instead of 84.4 degrees.
These are my steps.
magnitude of OA = \sqrt{}(3<sup>2</sup> + 2<sup>2</sup> + -6<sup>2</sup>)= \sqrt{}49 = 7
magnitude of OB = \sqrt{}](-6<sup>2</sup> + 6<sup>2</sup> + -2<sup>2</sup>)= \sqrt{}76
vector AB = (-9,4,4)
magnitude of AB = \sqrt{}(-9<sup>2</sup> + 4<sup>2</sup> + 4<sup>2</sup>) = \sqrt{}113
\Theta = cos-1 ((72 + \sqrt{}76 - \sqrt{}113) / (2*7*\sqrt{}76)) = approximately 1.5 degrees
I'm confused as to what to do here.
The next question has me confused as well, as I seem to be missing something key.
Please help!
These are my steps.
Don't put [ sup] or [ sub] tags inside [ tex] tags. The reason should be obvious.
Please help!
Your mixed tex and sup stuff is too hard to read, so I won't try to pick out the exact problem. Using the Law of Cosines (there's an easier way if you know about the dot product) and simplifying things a bit, you should get cos(theta) = 6/(7sqrt(76)). From this I get theta ~ 84.4 degrees. Make sure your calculator is in degree mode.
thanks. It was in radian mode. whoops. But what about my second related question? Can I do the same thing? And I do know about dot product, but I'm supposed to do the question without it.
Sure, the 2nd problem is almost exactly the same. The two sides adjacent to your angle are OP and AE.
