Finding aplitude of free undamped motion
  • Thread starter Thread starter Black Armadillo
    Motion
The discussion focuses on determining the amplitude and period of undamped harmonic motion for a mass weighing 32 pounds, which stretches a spring by 2 feet. The spring constant is calculated as k=16, leading to an angular frequency of ω=4 and a period T of π/2 seconds. The amplitude can be derived using the function f(t) = A cos(ωt) + B sin(ωt), where the maximum and minimum values can be found through differentiation or by converting the function into a single cosine function. The discussion emphasizes the necessity of solving a differential equation to fully understand the motion.
  • Understanding of Hooke's Law (F=kx)
  • Knowledge of angular frequency (ω) and period (T) in harmonic motion
  • Familiarity with differential equations and their solutions
  • Basic trigonometric identities and functions
  • Study the derivation of the differential equation for undamped harmonic motion
  • Learn how to convert between trigonometric forms of motion functions
  • Explore the application of the Pythagorean theorem in determining amplitude
  • Investigate the implications of initial conditions on the motion of harmonic oscillators
Students and professionals in physics, engineering, and mathematics who are studying harmonic motion, particularly those interested in solving differential equations related to oscillatory systems.
Black Armadillo
I have a problem I'm trying to solve:
A mass weighing 32 pounds stretches a spring 2 feet. Determine the amplitude and period of motion if the mass is initially released from a point 1 foot above the equilibrium position with an upward velocity of 2ft/s. How many complete cycles will the mass have completed at the end of 4\pi seconds?
I understand that F=kx so I can say 32=k(2) therefore k=16. And a period can be found by T= 2\pi/\omega where \omega=\sqrt{k/m}. So in this case \omega=4 and so the period, T, equals \pi/2. What I can't figure out though is how to find the amplitude of motion. Any ideas? Thanks for the help.
Since this is in the differential equations section I assume you need to solve a differential equation in order to get the information you need. Once you do so, the amplitude becomes obvious.
Have you tried constructing an ODE yet? Since it is undamped the solution is quite simple.
Presumably, you have a function of the form f(t)= A cos(\omega t)+ B sin(\omega t). There are two ways to find the amplitude:
1) Find max and min values by differentiating. f'(t)= -A sin(\omega t)+ B cos(\omega t)= 0 gives B cos(\omega t)= A sin(\omega t) so tan(\omega t)= A/B t= arctan(A/B)/\omega. Putting that back into the f(t) gives A cos(arctan(A/B))+ B sin(arctan(A/B)).
You could use trig identities to change those cosine and sine functions into tangents but simpler is this: imagine a right triangle with opposite side A, near side B. By the Pythagorean theorem, the hypotenuse has length \sqrt{A^2+ B^2}. Then the angle is arctan(A/B) and cosine of that angle is B/\sqrt{A^2+ B^2} while the sine is A/\sqrt{A^2+ B^2}.
2) Convert Acos(\omega t)+ Bsin(\omega t) to a single function. sin(x+y)= sin(y)cos(x)+ cos(y)sin(x) so, taking x= \omega t, we just need to find "y" so that sin(y)= A and cos(y)= B. Of course, we can't do that is A^2+ B^2 is not equal to 1 but we can fix that by multiplying and dividing by \sqrt{A^2+ B^2}.
A cos(\omega t)+ B sin(\omega t)= \sqrt{A^2+ B^2}\left(\frac{A}{\sqrt{A^2+ B^2}}cos(\omega t)+ \frac{B}{\sqrt{A^2+ B^2}}sin(\omega t)\right)
= \sqrt{A^2+ B^2}cos(\omega t+ y)
where y is such that sin(y)= A/\sqrt{A^2+ B^2} and sin(y)= B/\sqrt{A^2+ B^2}.
Of course, it is easy to look at that last formula and see what the amplitude is without need to find "y".
My trig is a bit rusty... How do you go from Acos(wt) +Bsin(wt) to sin(wt+y)
