Finding b_n - Binomial theorem problem
11 replies · 3K views · last reply
Saitama
Question:
If $\displaystyle \sum_{r=0}^{2n} a_r(x-2)^r=\sum_{r=0}^{2n} b_r(x-3)^r$ and $a_k=1$ for all $k \geq n$, then show that $b_n={}^{2n+1}C_{n+1}$.
Attempt:
I haven't been able to make any useful attempt on this one. I could rewrite it to:
$$\sum_{r=0}^{n-1} a_r(x-2)^r + (x-2)^n\left(\frac{(x-2)^{n+1}-1}{(x-2)-1}\right)=\sum_{r=0}^{2n} b_r(x-3)^r$$
I am clueless about the next step.
Any help is appreciated. Thanks!
Pranav said:
Question:
Attempt:
Hi Pranav!
Did you already expand it for $n=2$ and $n=3$?
Just to see if we can find a pattern?
I don't have a solution yet, but I can see that $b_n$ can be fully deduced from the terms starting from n up to 2n.
All terms below n are irrelevant.Let us define $c_t$ such that the sum is equal to $$\sum_{t=0}^{2n} c_t x^t$$.
That is, we have that:
$$\sum_{t=0}^{2n} c_t x^t = \sum_{r=0}^{2n} (x-2)^r=\sum_{s=0}^{2n} b_s(x-3)^s$$
With $a_{2n}=1$, we get that highest power $x^{2n}$ has coefficient:
$$c_{2n}=b_{2n}=a_{2n}=1$$
For $n=0$ we would be done, since $b_n = b_0 = \binom{2\cdot 0 + 1}{0+1} = \binom{1}{1} = 1$.Next is $c_{2n-1}$, which yields:
\begin{array}{lclcl}
c_{2n-1} &=& a_{2n-1} + \binom{2n}{1}a_{2n}(-2) &=& b_{2n-1} + \binom{2n}{1}b_{2n}(-3) \\
c_{2n-1} &=& 1 - 4n &=& b_{2n-1} - 6n \\
b_{2n-1} &=& 2n + 1
\end{array}
For $n=1$ we would be done, since $b_n = b_1 = 2\cdot 1 + 1 = \binom{2\cdot 1 + 1}{1+1} = \binom{3}{2} = 3$.Next is $c_{2n-2}$...
Sorry, that's as far as I got at this time. ;)
I like Serena said:
Hi Pranav!
b_{2n-1} &=& 2n + 1
\end{array}
Thanks for your input ILS! :)
But is there any proper way of doing it, I mean by some algebraic manipulation? I am thinking of differentiating both the sides wrt r number of times. I will see if I reach somewhere using that.
I have reached the right answer but I cannot perform a summation I come across midway in the solution.
Differentiating wrt r n times as I said before, I get:
$$\sum_{r=0}^{2n} r(r-1)...(r-n+1)a_r(x-2)^{r-n}=\sum_{r=0}^{2n} r(r-1)...(r-n+1)b_r(x-3)^{r-n}$$
$$\Rightarrow \sum_{r=0}^{2n} \frac{r!}{(r-n)!}a_r(x-2)^{r-n}=\sum_{r=0}^{2n} \frac{r!}{(r-n)!}b_r(x-3)^{r-n}$$
Substituting x=3 and using the fact that $a_k=1$ for all $k\geq n$,
$$\sum_{r=n}^{2n} \frac{r!}{(r-n)!}=n! \cdot b_n$$
I did the summation using Wolfram Alpha but how do I solve the summation manually? :confused:
Nope. I have no clue.
Looks like you're nicely going in the right direction, seeing how everything collapses.
Btw, your summations should start at n instead of 0 after taking the nth derivative.
Anyway, I can see that the summation can be reduced to a summation of combinations that add up to another combination.
And I can see that it holds true for a number of examples.
But as yet I have no clue how to prove it.
Sorry for the late reply.
Is there any alternative method if there is no way to solve the summation?
Thanks!
You have some typos
You are differentiating with respect to $x$ .
The nth derivative with respect to $x$
$$\sum_{r=n}^{2n} r(r-1)...(r-n+1)a_r(x-2)^{r-n}=\sum_{r=n}^{2n} r(r-1)...(r-n+1)b_r(x-3)^{r-n}$$
$$b_n =\sum_{r=n}^{2n} \frac{r!}{(r-n)!\, n! } $$
$$b_n =\sum_{r=n}^{2n} {n \choose r } $$
we need to prove that
$$\sum_{r=n}^{2n} {r \choose n } = {2n+1 \choose n+1}={2n+1 \choose n}$$
By induction on $n$
for $n = 1$ we have
$$\sum_{r=1}^{2} {r\choose 1 } = {3 \choose 1}$$
Next assume
$$\sum_{r=k}^{2k} {r \choose k } = {2k+1 \choose k}$$
and we need to prove that
$$\sum_{r=k+1}^{2k+2} {r \choose k+1 } = {2k+3 \choose k+1}$$
I will leave the rest for you.
Given $\displaystyle \sum_{r=0}^{2n}a_{r}\left(x-2\right)^r = \sum_{r=0}^{2n}b_{r}\left(x-3\right)^r$ and $a_{k} = 1$ forall $k\geq n$
Let $(x-3) = t$ Then $(x-2) = (t+1)$
$\displaystyle \sum_{r=0}^{2n}a_{r}(1+t)^r = \sum_{r=0}^{2n}b_{r}t^r$
$\displaystyle a_{0}+a_{1}(1+t)+a_{2}(1+t)^2+...+a_{n}(1+t)^n+a_{n+1}(1+t)^{n+1}+...+a_{2n}(1+t)^{2n} = b_{0}+b_{1}t+b_{2}t^2+...+b_{n}t^n+b_{n+1}t^{n+1}+...+b_{2n}t^{2n}$
Now camparing Coefficient of $t^n$ on both side and using $a_{k}=1$ forall $k\geq n$
$\displaystyle \binom{n}{n}+\binom{n+1}{n}+\binom{n+2}{n}+...+\binom{2n}{n} = b_{n}$
$\displaystyle \binom{n+1}{n+1}+\binom{n+1}{n}+\binom{n+2}{n}+...+\binom{2n}{n} = b_{n}$
Now using $\displaystyle \binom{n}{r}+\binom{n}{r-1} = \binom{n+1}{r}$ succesively
$\displaystyle \binom{2n+1}{n+1} = b_{n}$
Here $\displaystyle b_{n} = $ Coefficient of $t^n$ on $\bf{R.H.S}$
ZaidAlyafey said:
Next assume
This is where I got stuck...
However, the approach of jacks looks perfect! :)
Agreed , I should have tried it before posting , sorry .
Thanks a lot jacks! :)
BTW, my friend came up with exactly the same procedure this morning and I was going to post it here as soon as I reach home.
EDIT: Looks like you made it a bit lengthy. Rewrite the summation as:
$$\sum_{r=0}^{n-1} a_r(1+t)^{r}+ (1+t)^n\frac{(1+t)^{n+1}-1}{t}=\sum_{r=0}^{2n}b_rt^r$$
$$\sum_{r=0}^{n-1} a_r(1+t)^{r}+ \frac{(1+t)^{2n+1}-(1+t)^n}{t}=\sum_{r=0}^{2n}b_rt^r$$
Now we need the coefficient of $t^n$ on both the sides.
On the left hand side, we find the coefficient of t^(n+1) from (1+t)^(2n+1) as there is a $t$ in the denominator.
Hence, the coefficient of t^n on LHS is $\binom{2n+1}{n+1}$.
