Finding coefficien of kinetic friction
The discussion focuses on calculating the coefficient of kinetic friction for a pig sliding down a 35-degree incline. The pig takes twice the time to slide down the incline compared to a frictionless scenario. The equations of motion are established using Newton's second law, with the normal force and frictional force incorporated. The key conclusion is that the coefficient of kinetic friction (μk) can be derived from the difference in accelerations between the frictionless and frictional cases.
  • Understanding of Newton's second law of motion
  • Basic knowledge of trigonometry, specifically sine and cosine functions
  • Familiarity with the concepts of normal force and frictional force
  • Ability to apply kinematic equations for constant acceleration
  • Calculate the coefficient of kinetic friction using the derived equations
  • Explore the effects of varying angles on frictional forces
  • Investigate the relationship between time, distance, and acceleration in inclined planes
  • Learn about frictional forces in different materials and their applications
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the dynamics of friction on inclined surfaces.
sjcorona
A slide loving pig slides down a 35 degree slide in twice the time it would taken to slide down a frictionless 35 degree slide. What is the coefficient of kinetic friction between the pig and slide?
So with the frictionless slide I found ax=8.03m/s^2 but without velocity or the length of the slide I'm not sure how to find time. So i shifted to the slide with friction,
Fy= n-mgsin(35)
0=n-mgsin(35)
N=mg sin(35)
Fx=-fk+mgcos(35)
Fx= mg(-μksin(35))+(cos(35))
M*ax=^
Ax=g(-μksin(35))+(cos(35))
I definitely can't use the same value of acceleration right? Because the first acceleration assumed no opposing force.
Pick an arbitrary length for the slide. You'll find that it'll cancel out of the equations. Use the time-distance formula for constant accelerations. Determine acceleration for each case first.
  • · Replies 20 ·
13K
  • · Replies 21 ·
