Finding Constants to Solution Given 2nd Order, Nonlinear DE
The discussion revolves around finding constants A and B in a second order nonlinear differential equation that describes a fermion at rest. The equation is given as (d^2phi/dt^2)-(d^2phi/dx^2)-phi+phi^3=0, with a proposed soliton solution of Phi(x)=A(tanh(Bx)).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various methods for differentiating the proposed solution and substituting it back into the differential equation. There are attempts to simplify the equation using hyperbolic identities and to express the equation in terms of polynomials. Some participants question the correctness of differentiation and the implications of setting certain terms to zero.
The discussion has seen various attempts to differentiate the solution correctly and to manipulate the resulting equations. Some participants have suggested that finding suitable values for A and B could simplify the problem, while others have expressed confusion over the differentiation process. There is acknowledgment that phi = 0 is a solution, but the exploration of alternative solutions is ongoing.
Participants are working under the constraints of a homework assignment, which may limit the methods they can employ. There is also a mention of differing opinions from professors regarding the feasibility of finding the constants.
rakeru
Okay, here's the deal:I have been given a second order nonlinear differential equation, and I have also been given the general solution with constants A and B. I am supposed to find the constants A and B. The solution represents a fermion at rest, since the solution does not vary with time.
The differential equation is as follows: (d^2phi/dt^2)-(d^2phi/dx^2)-phi+phi^3=0
The soliton solution is:Phi(x)=A(tanh(Bx))
I have five pages of attempts to solve this. One professor told me it was impossible, but the professor that I am doing research with told me that it is possible. First, I found the first and second derivatives of phi, then, I input them into the differential equation. The first term goes out because the particle is at rest. Then, I tried different methods.
I tried using hyperbolic trig identities.
I tried writing the equation in terms of sinh and cosh and then tried to eliminate some things. He told me that I need to end up with a polynomial that has A and B and no x, and that I must have hyperbolic tangent on both sides of the equation to find the constants.
I also tried getting a polynomial with tanh(Bx) representing a variable p and then I got factors A, p, and the polynomial. If the equation equals zero, then at least one of those factors must be zero, so I set them equal to zero, but I still have x in there. I tried setting tanh (Bx) (aka p) equal to zero and setting the polynomial to zero and then I solved the polynomial for p and made the p equation equal to zero, however, it looked very complicated and the professor said it was a simple calculation, and even then, that would mean that phi is zero, and that is not the case because I am supposed to use phi to get energy density.
Please help.
I think you're making this harder than it is. The solution is just a 2-3 lines. Can your write down d^2phi/dx^2? Do you remember that 1-tanh[x]^2 = sech[x]^2. Also remember that you are trying to find an A and B that solve the equation, so you are free to choose A and B to make the problem simplify.
d^2phi/dx^2= -2AB^2tanh(Bx), correct?
Now I have gotten the equation
tanh(Bx)[2AB^2-A+A^3tanh^2(Bx)]=0
I set 2AB^2-A+A^3tanh^2(Bx)=0
tanh(Bx)= sqrt[2B-1]/A
But now what? Was I supposed to change the tanh^2(Bx) into 1-sech^2(Bx)?
No. You're not differentiating this correctly. The first derivative of tanh(x) is sech^2(x). The second derivative is more complicated than just tanh[x]. Try again.
phi''=-2AB^2tanh(Bx)sech^2(Bx)= -2AB^2tanh(Bx)+2AB^2tanh^3(Bx)
and so
tanh(Bx)[2AB^2-A]+tanh^3(Bx)[-2AB^2+A^3]=0
I keep getting that phi is zero.
OK, better. Of course phi = 0 is a solution, but there is another solution. Suppose those two coefficients (2AB^2 -A), and (-2AB^2+A^3) are both zero. Is there a set of A and B that can make that happen?
Ahhh yes. I understand!
Thank you very much :)
Alright, I ended up with A=+/- 1 and B=1/sqrt(2).
Sounds good to me. See, it wasn't that hard after all!
