Finding current and potential difference with Kirchhoff's laws
10 replies · 3K views · last reply
WeiLoong
https://fbcdn-photos-c-a.akamaihd.net/hphotos-ak-xft1/v/t1.0-0/s480x480/12802893_10205707400875867_4855727067132215897_n.jpg?oh=b486598e6f2016a814eb52bf48870334&oe=57648CD9&__gda__=1464637082_3cae40328f43f09eaa2cf9cf5b2f0b0f
Kirchhoff Law
1. Find the current in the circuit
2. Find the potential diferent between X and Y
1 by using the kirchhoff law. V=IR
I=0.025
question 2 I=0.025
but how to find Vx and Vy?
Vx =IR
I =0.025 but which R is supposed to use?
Your current direction is correct. One way to solve this problem would be by assigning potentials and calculating voltage drops. Assume potential of point W to be 0V. That way, +ve terminal of 20V source will be at 20V. Then calculate drop across 40 ohm resistor. Point x will be at 20-V40Ω potential. Go on with this along the loop and find potential of point y. Difference between them is your Vxy.
Thanks! I got it
https://scontent-kul1-1.xx.fbcdn.net/hphotos-xlt1/v/t1.0-9/12814145_10205707617681287_7591958914593573074_n.jpg?oh=b9163aaa1c77737cb533a124e4292d6a&oe=574F8189
By using kirchhoff law i get all the current
the question ask to find the PD between A and B, the question is the voltage drop i should begin in which point? Because there is 2 sources
You can start by either assuming A at 3V or assuming B at 0V. Since you know i1, assuming B at 0V will be easier.
But point A is supplied by 2 battery of 3V.If i use voltage drop, I only need to look at the top loop?
You need to find the currents using the two loops (which will include both the sources) and then by assuming a suitable reference( VB=0V), you can find Vab like you did in the last problem.
WeiLoong said:
if i assume Vb =0
-6(I2)+3V=Va?
-6I1+3V=Va..
Ops mistake haaha. thank you , have a good day!
https://scontent-kul1-1.xx.fbcdn.net/hphotos-xft1/v/t1.0-9/12814383_10205707793045671_2997254212403029818_n.jpg?oh=0a9ed6d9fbec4f8eed32f88ffdfba9b1&oe=57574AC1
If Vx is 0 , what is the V in point Y
-12(I1)-8(I2)=Vy
which i will gef -12V in Y, is this possible for me to get 12V in negative value?
-12(I1)-8(I2)=Vy
Yes. In fact you don't even need to know the current for that. Moving from x to y along the bottom wire, you can see a voltage drop of 12V.
