Finding current in a circuit with a 3V source
32 replies · 4K views
nchin
http://imageshack.us/photo/my-images/585/circuitzzz.png/
i thought maybe i should ignore everything that is on the right side of the 3v and just focus on the left side. but this one is not looking too good for me.
any ideas on this one??
It looks like it should respond to mesh analysis.
What's the problem?
One way to sort your head out about this sort of problem is to redraw the circuit in a way that makes more sense to you. Since there is an explicit ground in this diagram, it may help to draw a ground rail across the bottom of the page and draw the other components in above that ... i.e. the ground rail has three resistors connected to it...
find volt across the 2mA source
What's the problem?
how many mesh loops do we have here??
Yes, it is a good idea. See picture.
ehild
A fair few - but you don't need all of them.
ehild
I1 = V/R
Resistors add up right?
I1 = 3/3+3+2+3+2
ehild
i found i1 = 0.6409 A
i2 = 0.2307
total Resistance = 13.588Ω
so i1 - i2 x total R = volt across the 2mA?
is that correct
nchin said:
I1 = V/R
I1 = 3/3+3+2+3+2
No.
Only resistors in series add up. There is I2 current flowing through the left 2kΩ resistor. It is not in series with the other ones.
ehild
ehild said:
No.
ehild
i see, so what do i do? I am not sure how to solve I1, i think i did I2 correctly though
i think i got it, since one of the nodes are grounded out
I1 = 3/6+5 = 0.2727A right?
Write KVL for the loop in the figure, and substitute I2 = I1+2
ehild
ehild
applying KVL = 6I1 - 3 +5I1 + 2I2= 0?
yes.
ehild
ehild said:
yes.ehild
it should be .002 right? because 2 mA = .002 A. after i got the currents, what would the total resistor be to plug in the equation V = i x R?
Also I got I1 = -0.2727A and I2 = 1.727A
do i add them together to get the the current i need to solve the problem?
1.727 + (-.2727)?
You substituted the resistance in kΩ-s, then the currents must be in mA.
What should be 0.002?
ehild
ehild
oh i see. i thought it was KVL = 6I1 - 3 +5I1 + .002I2= 0
im not sure what I am suppose to do after i got the currents though
You multiply the current with the resistance to get voltage.
Have you got the currents? What are they?
ehild
ehild
I1 = -0.0769 mA
I2 = 2.079 mA
correct?
6I1 - 3 + 5I1 +2(I1 + 2 ) = 0
13I1 = -1
I1 = -0.0769mA
I2 = 2 + -0.0769 = 2.0769mA?
im trying to find the voltage across the 2mA
and I2=2+I1. (I are in mA)
What are I1 and I2?
Solve.
ehild
13I1 = -1
I1 = -0.0769mA
Correct?
What do I do next?
Look at the loop with the current source. What are the voltage across the resistors?
ehild
ehild
V = IxR
VR5KΩ = 2.0769 x 5 = 10.2845 V
VR2KΩ = 2.0769 x 2 = 4.1538 V
vR1KΩ = 2.0769 x 1 = 2.0769 V
correct?
would the final answer be just adding up all the volts?
nchin said:
V = IxR
correct?
No, I2 flows through the vertical 2kΩ resistor only. The others have the generator current.And your I2 is not correct. Write up KVL again for the loop in the figure. The voltage drop across the generator is Ug. Determine Ug.
ehild
ehild said:
No, I2 flows through the vertical 2kΩ resistor only. The others have the generator current. Write up KVL again for the loop in the figure. The voltage drop across the generator is Ug. Determine Ug.
ehild
5I2 + 2I2 + 1I2 = -2
8I2 = -2
8(2.08)=-2?
Why did we need to find the voltage across each resistor at first ?
It is wrong. Write the voltages. What current flows through the 1 kΩ and 5 kΩ resistors? What is the current through the 2 kΩ resistor? ehild
ehild
V = I x r
I2= 1.9231
V2 kohm = 1.9231 x 2 = 3.85v
V5kohm = 2mA x 5 = 10.0v
V1kohm= 2mA x 1 = 2.00v
