16Candles
- 6
The right side of a wire loop is dragged to the left across the south pole of a magnet. What will be the direction of the current induced in the loop?
a. No current will flow around loop.
b. Current will move in the wires of the loop in the same direction as the loop itself.
c. Current will move in the wires of the loop in the opposite direction as the loop itself.
d. Current will oscillate back and forth around the loop (AC current)
e. Current will flow clockwise around the loop.
f. Current will flow counter-clockwise around the loop.
2. The attempt at a solution
Because of the right hand rule, would the current be moving counterclockwise (f)?
Also does the magnetic field point to the right?
What difference does it make when the right side is dragged vs the left side?
Also, why does a down direction of t he current cause a clockwise current throughout the loop as opposed to a counterclockwise current?
How do you know if the current will move in the wires or around the loop? Can I eliminate b and c because an induced current involves moving a loop over a magnet?
Please help, I'm very confused!
