Finding distance with the conservation of energy equation
The discussion focuses on solving a physics problem involving the conservation of energy to find the maximum height of a baseball thrown at an angle. The initial kinetic energy (KE) of the baseball, calculated as 67.5 J using the formula KE = 0.5 * m * v², was confirmed to be correct. The participant initially miscalculated the potential energy (Uf) in their energy conservation equation, leading to an incorrect maximum height of 4.96 m. After correcting the mass in the potential energy term, the correct maximum height of 16.6 m was achieved.
  • Understanding of kinetic energy (KE) and potential energy (PE) concepts
  • Familiarity with the conservation of energy principle
  • Basic knowledge of projectile motion and its components
  • Ability to manipulate algebraic equations for solving physics problems
  • Study the derivation and application of the conservation of energy equation in various contexts
  • Learn about projectile motion and how to resolve velocity into horizontal and vertical components
  • Explore the concept of maximum height in projectile motion and its calculation methods
  • Practice solving similar physics problems involving energy conservation and projectile dynamics
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of problem-solving in projectile motion.
asdf12321asdf
3. A baseball (m = 0.150 kg) is thrown with an initial speed of 30.0 m/s at an angle of 37.0 degrees from the horizontal at y = 0 m. (a) Find the initial KE of the ball. (b) Use conservation of energy (not kinematic equations) to find the maximum height reached by the ball. (Hint: Does the ball have any velocity at its maximum height?)
KEf + Uf = KEi + Ui
(.5)mvf² + mgyf = (.5)mvi² + mgyi
(a) Part a I got the correct answer, but can you tell me if I did it the correct way. I did (.5)(0.15)(30)² = 67.5J
(b) What I tried was using KEf + Uf = KEi + Ui . For the velocity at the top I accounted for the angle and got that the velocity in the x direction was 24.0m/s So I did:
(.5)(0.15)(24.0)² + (.5)(9.8)y = 67.5 (from part a) + (0.15)(9.8)(0)
Solving for y I get 4.96m, but that is not the correct answer. I'm not sure if I am doing it the wrong way or if I made some error somewhere, so any help would be appreciated.
Thanks
You did 'a' correctly.
For 'b', check your Uf.
Oh wow, thanks a lot. I changed the m in Uf to .15 and then got 16.6m which is the correct answer. It's unfortunate I've spent all this time on this problem due to this small error, though it's reassuring to know I was doing it the right way at least. Thanks again!
12K
