MHB Find Dot Product Between Vector CD & Vector K
To find the dot product between vector CD and vector K, first, vector CD is calculated as <-2, 4> from points C(2, 6) and D(0, 10). Vector K, which is perpendicular to vector A (-3, 2) and has the same norm, is determined to be <-2, -3>. The calculations confirm that K maintains a negative x-component and satisfies the conditions of being perpendicular to A. The dot product of vectors CD and K can be computed as CD · K = (-2)(-2) + (4)(-3) = 4 - 12 = -8.
sp3
Hi! I'm given 2 points C(2;6) and D(0;10), a vector A with its components = (-3, 2). I'm asked to find the dot product between vector CD and an unknown vector K, knowing that K is perpendicular to A, same norm as A and with a negative x-component. I know that perpendicular means the dot product=0 and vector CD has a norm \sqrt{40} if i calculate it, but I have no clue how to solve it (we can't have a calculator).
Thank you for your help!
Mathematics news on Phys.org
vector K would be $\left<-2,-3\right>$
vector CD would be $\left<-2,4\right>$
can you find the dot product?
Thanks for the reply, how did you find vector K?
two ways ...
1. $\vec{A} = \left<-3,2 \right>$ has slope $m = -\dfrac{2}{3} \implies \vec{K}$ has slope $m_{\perp} = \dfrac{3}{2}$.
since $\vec{K}$ has a negative x component, then so does its y-component ... same magnitude means $\vec{K} = \left<x,y \right> = \left<-2,-3 \right>$
2. let $\vec{K} = \left<x,y\right>$
$\vec{A} \cdot \vec{K} = -3x + 2y = 0 \implies y = \dfrac{3}{2} x$
$|\vec{A}| = |\vec{K}| \implies \sqrt{(-3)^2 + 2^2} = \sqrt{x^2+y^2} \implies x^2+y^2 = 13 \implies x^2 + \dfrac{9}{4} x^2 = 13 \implies \dfrac{13}{4} x^2 = 13 \implies x = \pm 2$
$x < 0 \implies x = -2 \implies y = -3$
Equivalently, one vector perpendicular perpendicular to (a, b) with the same norm is (-b, a), another is (b, -a). Here, K= (-3, 2) so those two perpendicular vector are (-2, 4) and (2, -3). The first has x component negative.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
