Finding E on the Z Axis: A Differential Approach
  • Context: Undergrad
  • Thread starter Thread starter ozone
    Charges Polygon
5 replies · 5K views
ozone
Imagine you have a regular 13 sided polygon with charges distributed on every corner of the polygon.
What would a test charge experience in the center?
The answer to that was a 0 net force (which makes some intuitive sense to me due to the symmetry of the polygon). I understand that if we were to place a force in the
However what would happen if one were to remove one of the charges?
Thanks.
Just draw the 12 arrows and you´ll see the result.
Alright that seems like a reasonable way to go about this.. I guess I just want to double check too that describing the symmetry of the polygon is an adequate way to solve this problem, and if there was a more elegant way to answer the problem.
and a nicee idea!
imagine we have an N gon on xy page.we want to find the E vector at some z(out the page over the center of polygon) but not actually OVER the center.say we move away from the axis z(which starts at O which is the center of polygon) a tiny length delta .it means in cylindrical coordinates we are at z(z) and delta(r) and some phi(which won't matter).to the first nonzero order of delta we want the E vector.
the idea:finding E on the z axis is fairly easy.(because of symmetry).the trick is to take a differential cylinder near the point on the axis and write divergence>>everything going in comes out.things which go in is Ez from below and Ez+dz comes out .also from the sides of cylinder E r comes out.(we want E r)equating the flux simply gives the desired E.nicee!
