Finding expression for non-uniform current density of a wire
The discussion focuses on deriving an expression for the current density J in a wire with a non-uniform current density proportional to the distance s from the center. The proposed solution is J = 2*s*I/R², which the poster believes integrates correctly to yield the total current I. However, there are concerns about the correctness of the expression and the need for a proper derivation. It is highlighted that integrating over the cross-sectional area, including the angle, is necessary for accuracy. The conversation emphasizes the importance of showing work to support the derived expression.
phys-student
A long, straight wire, radius R, carries total current I. The current is distributed in the wire so that the current
density is proportional to s, the distance from the center of the wire.
(a) Write an expression for the current density J in the wire, as a function of s.
J=dI/da
J=2*s*I/R2
I'm pretty sure my attempted solution is correct because when you integrate J from 0 to R with respect to s you get the total current I. However I kinda just pulled this out of thin air and I'm pretty sure I won't get full marks without showing my work. Is there a different way to do this besides just making up an expression for J like I did?
How would you express this statement in mathematical form?
I don't know, that's what I'm trying to understand. I was trying to express that statement in mathematical form but couldn't figure it out, so I settled on the expression that I have simply because integrating it over the cross section of the wire results in the total current I
J=dI/da
J=2*s*I/R2
I'm pretty sure that's not right. Even the units are wrong.
Likely you're not integrating over an area.
Yep you're right. Totally forgot that I also need to integrate over the angle from 0 to 2 pi
Okay I'm good now, thanks
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 0 ·
  • · Replies 23 ·
