MHB Finding expressions for the five other trigonometric functions....
TrigEatsMe
So here's the question:
Suppose cos(θ) =x/4. Find expressions for the other five trigonometric functions in terms of x.
In our practice problems we never had a variable x used and we were able to use the pythagorean theorem to determine the final side of the triangle and simply figure out the relationship using soh-cah-toa.
The x is throwing me off and the fact that the question doesn't specify that it's a right triangle...but perhaps that's a given since they specified that it was an angle with a cosine in the fourth quadrant?
In any case, all I've got is that sec(θ)=4/x. :(
I have a feeling there's some identity or something I should be using -- even a hint would be greatly appreciated.
- - - Updated - - -
Additionally -- it does not specify whether it's a 45/45/90 or 30/60/90 triangle which would have been helpful as well.
Mathematics news on Phys.org
Hi TrigEatsMe, (Wave)
The fact that there is an $x$ actually doesn't make it any harder!
$$\cos\left({\theta}\right)=\frac{x}{4}=\frac{\text{adjacent}}{\text{hypotenuse}}$$
From this, we can construct a right angled triangle (it need not matter whether it's 30-60-90 or 45-45-90). Using Pythagorean theorem, and knowing that the adjacent side is $x$ and the hypotenuse is $4$, how can I find the opposite side?
Remember that if we have the values of all three sides, we can easily find the other ratios:
$$\sin\left({\theta}\right)=\frac{\text{opposite}}{\text{hypotenuse}}$$
$$\tan\left({\theta}\right)=\frac{\text{opposite}}{\text{adjacent}}$$
The inverse trig ratios follow from this. :D
Thanks for such a quick response! I must be missing something, though.
a^2 + b^2 = c^2
so I have x^2 + (b^2) = 16
The question asks for me to provide the other five trig functions in terms of x. I'm not seeing how to find out what that opposite side is -- what is its relationship to the adjacent side unless it's a 45-45-90 or 30/60/90?
Sorry :(
Picking up where Rido12 left off...take this from the basic definitions, and yes, we are going to use the Pythagorean Theorem, but in a different way. You have [math]cos( \theta ) = x/4[/math]. We also know that [math]sin^2( \theta ) + cos^2 ( \theta ) = 1[/math], so if we know [math]cos( \theta )[/math] we can get [math]sin( \theta )[/math]. Give it a try.
-Dan
a^2 + b^2 = c^2
Sorry :(
You're getting there and you want to remove the variable $$b$$. Can you find an expression for $$b$$ in terms of $$16 \text{ and } x^2$$
[math]b = \sqrt{16-x^2}[/math]
Here is a picture in case a visual aid helps
I used $$A$$ instead of $$\theta$$ to save my poor drawing hand!
Once you know all three sides you can work out the other trig ratios. Start with $$\sin(\theta)$$ and $$\tan(\theta)$$ and use those to find the others. Your answer will be in terms of $$x$$ but that's expected and correct in this case
Thanks for all your help, folks -- I was able to get it submitted in time and assuming I got the answer correct I wills post what I submitted sometime tomorrow. If I didn't...well, I'll post it anyway so someone can correct me. ;)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
