Finding f and d in Lab Experiment
6 replies · 4K views · last reply
lionely
I have to find f and d
Here's the method of the lab
Method: The length of the opening in the ray box was measured and
recorded. The equipment was set up as shown in the diagram.
The distance, x, of the tube from the screen was varied and
recorded. The magnification, m, for each value of x was
determined and recorded; this was obtained by focusing
the image of the cross-wire formed on the screen and
measuring the length of the image using the graph
paper attached to the screen. At least 8 values of x
and m were determined. A graph of m against x
was plot and a best straight line was drawn through
the points. Theory suggested that
m = (x + d) - 1
f
By writing the equation above in the form y=mx + c,
the focal length of the lens and the position of the lens
from end A of the cardboard tube was determined.
Diagram of a lens experiment: ray box on the left, lens inside a cardboard tube with ends A and B, distances d and x marked, and a screen on the right; below, a front view of the ray box showing a cross-wire opening with a 1 cm dimension and a hole.
m = (x + d) - 1
f
I plotted a graph of m against x gradient = m/x
so gradient would = 1/f right?
then i could solve for d after?
Hi lionely. Can you post the diagram?
lionely said:
2. Homework Equations
m = (x + d) - 1
f
Just to make sure, is this the equation?
##m = \frac{x+d}{f} -1##
Yes, the gradient (slope) would be 1/f. The y-intercept of your graph is related to d. So, you could use the y-intercept to find d.
I get a negative value when i try to work out d... I think something is wrong.
