Finding gain equation for inverting op-amp with third resistor and voltage source
  • Thread starter t3rom
    Intro
13 replies · 2K views · last reply
t3rom
For inverting op-amps Vout = -Vin(R2/R1)
But I've no clue what happens when you add third resistor with a voltage source to the amplifier. Is there a general gain equation for such circuit?
See the attached problem in the image.
I tried calculating for the R1 and R2 but the answer is wrong.
I will be grateful if someone can help me understand it by solving it. Thanks!
  • Hand-drawn op-amp circuit with a 5k resistor from a 100mV source and a second 5k resistor from a 200mV source feeding the inverting input, a 10k feedback resistor from the output to the inverting input, non-inverting input grounded, labelled Vout = ?
You must have studied superposition principle in Circuit Analysis. Can you tell us what it is?
Thanks for replying!
No, I haven't. I'm only taking a basic course where they tell you an equation and you plug in the values. Theorems etc. are beyond the scope of the course.
What about Nodal Analysis?. Nodal Analysis is tought in basic physics courses.
There is just one node to care for. The Op-Amps inverting input terminal
What is the Voltage at this Node?
Write its node equation?
Try it by applying Kirchoff's current law. You have an ideal OP amp so no current flows into the terminals. Find expressions for the currents flowing into the node from the two voltage sources and subtract the current flowing out of the node from this. KCL states that this will be equal to zero. Find in terms of Vi or Vo.
I did this (see attached)
Please have a look at my original op-amp circuit too. Thanks!
  • Handwritten op-amp derivation: left, an inverting amplifier circuit with R1, R2, R3, sources V_A and V_2, and output V_o; right, KCL node equations, ideal op-amp note V_N = 0, and the final result V_o = 200 mV.
Thats good work. There is just ine mistake. That too of just one negative sign In the Nodal analysis we take Voltage coming at the the. Why did you take In leaving the Node. Reverse the dirction of In. Your first equation will become
I1+I2+In = 0.
There is nothing wrong in taking In leaving the node. But it leads to errors as you have done in next equation itself. If you are reversed the direction of In, you have to reverse the order of voltages.
You can do either way but the better method would be reversing the direction of In.
Ah I see, it should have been -(Vn/R2-v2/R2)=0 if I stick with my current In direction, or +(V2/R2-Vn/R2) if reverse the direction of In making i1+i2+in=0. Thanks for helping me out, but mostly motivating me with hints!
You are welcome.
The circuit you just solved is a 'Weighted Summer', where the output is weighted sum of input voltages. The general Vo for Weighted Summer is given by
Vo = -Rf{(V1/R1)+(V2/R2)+(V3/R3)+...+(Vn/Rn)}
Where Rf is the resistance in the feedback path and R1, R2...Rn are the resistance connected with the input voltages. In your problem n=2.
Cool! My Vo equation conforms it :)
Can you kindly recommend any good book on intro to circuit analysis which is easily accessible?
Thanks again! :)
There are many good books on Circuit Analysis. It is really hard to recommend one. But the best i think is by 'Hayt & kimmerly(Linear Circuit Analysis)' It stars from basics.
But i would recommend two other books. One is by 'Decarlo & Linn(Linear Corcuit Analysis)' and the other one is by 'Van Valkenburg(Network Analysis)'.
You can refer to anyone of the three books i recommended. All three are good books.
