Finding general solution for ODE.
The discussion focuses on solving the differential equation dy/dx = (y+3)(y-5). The user successfully separates variables and integrates, arriving at the equation (1/8)*(log(y-5)-log(y+3)) = x + C, but struggles with rearranging it to solve for y. Clarifications are provided that solving for x is unnecessary, and instead, the focus should be on expressing y as a function of x using logarithmic properties. The user also inquires about determining the domain of the solution and how to apply initial conditions to find the constant C. Overall, the conversation emphasizes the steps needed to derive the general solution and the importance of understanding the function's domain.
Lengalicious
For the following differential equation:
1) Provide the general solution
2) Discuss for which values of x the solution is defined.
3) Find the solution of the initial value problem y(0) = 3
dy/dx = (y+3)(y-5)
1) so I separate variables and get (1/8)*(log(y-5)-log(y+3)) = x + C after integration.
Now i need to solve for x right? How would I go about doing this? Can't seem to figure out how to rearange.
2) I don't think i can do this until i find the general solution? But once its found do i just find its domain?
3) For this i just substitute the initial values in, solve for C and then place back in equation?
dy/dx = (y+3)(y-5)
1) so I separate variables and get (1/8)*(log(x-5)-log(x+3)) = x + C after integration.
How did you get ∫dy/[(y+3)(y-5)] = (1/8)[log(x-5)-log(x-3)]?
RGV
sorry replace the x's with y's that was a typo. And i did it by splitting into partial fractions then integrating each term simply. Was that not correct?
dy/dx = (y+3)(y-5)
You don't need to solve for x; it is already done---just read your own equation! Now, if you wanted to solve for y as a function of x, that would involve a bit more effort, but is still just elementary algebra: use standard properties of log to do it.
RGV
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
