Finding Height With Projectile Motion
The problem involves a brick thrown upward from a building at an angle of 10.1° with an initial speed of 6.74 m/s, and it requires determining the height of the building based on the time of flight and the effects of gravity.
  • Participants discuss the appropriate equations for projectile motion, particularly focusing on the vertical component of the initial velocity. There are questions about the correct interpretation of the angle and its impact on the calculations. Some participants express confusion about the initial height and the use of the equations.
Guidance has been offered regarding the correct use of equations and the importance of the vertical component of the initial velocity. Participants are exploring different interpretations of the problem and clarifying their understanding of the physics involved.
There is an ongoing discussion about the assumptions made regarding the initial velocity and the angle of projection. Some participants have noted potential misunderstandings in applying the equations of motion.
Slovan
A brick is thrown upward from the top of a
building at an angle of 10.1◦
above the horizontal and with an initial speed of 6.74 m/s.
The acceleration of gravity is 9.8 m/s^2.
If the brick is in flight for 2.5 s, how tall is
the building?
Answer in units of m
x=vix*t
y=viy*t+.5*g*t^2
y=viy*t+.5*g*t^2
=(((1/2(9.8m/s^2))2.5s^2)
=30.625m
The answer is incorrect, what have I done wrong in my calculations?
A couple things:
The equation you want to use should be y = yi + viyt + 0.5gt2
Also, you do not seem to be using viy in the incorrect equation you are using.
What lewando said and be careful with the signs.
the building?
x=vix*t
y=viy*t+.5*g*t^2
y=viy*t+.5*g*t^2
=30.625m
I think you have completely misunderstood the formulas you are trying to use. What became of "viy*t"? You understand that the initial upward velocity is NOT 0 don't you?n What do you think "a brick is thrown upward" means. And you have not used the fact that it is thrown at "an angle of 10.1 degrees above the horizontal". What does that mean and how does it affect your formula?
lewando said:
A couple things:
Thanks for the reply. But I do not get where yi came from? Can you please explain to me.
Thanks for the reply. I see that my mistake here is that i assumed viy would automatically equal 0 and that I mixed it up. I also assumed when the problem said the brick is thrown upward it meant being thrown at an angle of 10.1 degrees forming a sort of triangle till it reaches its peak. So what I think it means is that i have to calculate the x distance traveled and the y distance traveled using sin and cos. Am I on the right track?
I would define:
yi as the initial height.
y as the height at time t.
There are variations of this equation that could lead to confusion.
d = viyt + 0.5at2, where d = y - yi
Also, as CWatters pointed out, be careful with signs. The equation I posted:
as written, uses "g" as -9.81m/s2
No triangles in projectile motion.
The x-distance and the x-component of the initial velocity, vix are not important. The y-component of the initial velocity, viy is important. Can you determine what viy is? Yes, a trig function applies.
No.
You use trig to work out the vertical component of the initial velocity and plug that into an equation of motion.
In this particular problem you can ignore what's happening in the horizontal plane. They only ask for the height of the tower not the horizontal distance travelled.
Sorry if this sounds like a stupid question but how would I find the y-velocity? And if I do I would have to do
y-velocity divided by 6.74 m/s times cos10.1?
The initial velocity is given as 6.74m/s in a direction 10.1° (assumed above the horizontal).
This velocity vector can be represented as the sum of two vector components: one in the x-axis direction (horizontal) and another in the y-axis direction (vertical).
Your job is to find the one in the y-axis direction. Here is a good refresher link:
http://hotmath.com/hotmath_help/topics/components-of-a-vector.html
Close. That would be the horizontal velocity not the initial vertical velocity.
Ok thanks guys, I was finally able to solve it! Thanks for your time guys!
