Finding individual marble mass from group measurements
80 replies · 9K views
hutchphd said:
Please show all the data (where are the 31.5g samples?). Get organized please. Then suppose the marbles are ~4g. Does this work? What is the weight of the empty?
Masses of all 10 containers in ascending order:
11.0 g
11.1 g
20.6 g
21.4 g
21.5 g
25.7 g
25.8 g
25.9 g
31.6 g
31.9 g
Largest mass: 31.9 g
Approx weight of one marble: 4 g
Mass of empty container: minimum of 3 g
(31.9 - 3)/4 = 7 marbles in largest container
This is wrong, I don't follow what you are saying, can you please explain?
orangegalaxies said:
Step 2: I already found the differences in mass, could you explain more on what I need to do?
As I already said,
kuruman said:
Why take differences and how do they help you guess the mass of one marble?
As implied by what I said, what you need to do is first figure out what the difference in masses is equal to and, once you answer that, guess the mass of one marble. The number should be consistent with you already know or is given.
hmmm okay so for the 31-32 g container, i did 31-3 and then divided this by 4, but this is wrong like you said. I'm not sure as to what else i can do :')
Why did you do this? Container+marbles masses at 32g. There are at most 6 marbles by question. What is minimum possible mass of container?
kuruman said:
As I already said,
The difference in masses:
0.1 g
9.5 g
0.8 g
0.1 g
4.2 g
0.1 g
0.1 g
5.7 g
0.3 g
Average difference in masses: 2.32 g
Is this then the mass of one marble? Ahhhh it won't work for the larger marbles so I don't think so
3 g. Pls chill, I'm new to these concepts, not an expert so I won't be able to understand things unless you explain them. My teacher is crappy and won't explain either.
  • Sad
I think that 3 gram minimum is inaccurate, and is resulting in extra confusion. I estimate the container to be closer to 2 grams.
hmmmm. these are the values my teacher gave me...
Apologies. You almost got it but you need to choose best values from noisy data:
Can't be 7 marbles by definition. Mass of marble is more like 4.5, Try another guess. It won't be perfect.
Now make guess and plot mass vs # marbles for all data points.
If you look at the data, at first glance, (I'm sure you observed it as well), there appears to be increments of between 4.5 and 5 grams. There is a jump from 11 to 21, but with a small sample, it's not surprising that the 16 is absent.
Can you explain how you got 4.5 g?
Assuming each marble is 4.5, and the empty container is 3:
Mass : Number of marbles
11.0 g = ~2
11.1 g = ~2
20.6 g = ~4
21.4 g = ~4
21.5 g = ~4
25.7 g = ~5
25.8 g = ~5
25.9 g = ~5
31.6 g = ~6
31.9 g = ~6
Yeah you're right that is a patterm
I just spotted something else=they give you the weight of the container to be at least 3 grams=it might even be large enough to make the 11 g have just one marble=my previous post on this being inaccurate and possibly 2 grams was incorrect.
I disagree I think it is more like 6g. The problem says >3.
see my post 42 :)
This is also true yeah
Yes Now the OP needs to graph the data, draw the best linear fit. Slope gives marble mass, intercept gives container mass
graph the differences in masses?
Graph y=total measured mass vs. x=number of marbles
y value for x=0 gives mass of container.
Your eyeball and ruler will draw the "best" line pretty well. Gives the best fit to all the data.
is there a way to solve this problem without graphing? my teacher never mentioned graphing, they only said you need to find the averages. they are a pretty bad teacher tbh but i wanted to confirm
Plot every point and then make the best line ...better than averages (apologies to your teacher).
in your previous post, is there any way you found the marble mass = 4.5 g? calculations i mean
Rough graph in my head. Do the graph. Excel for graph?
Your head does a good "least squares fit" to the straight line.
hutchphd said:
Rough graph in my head. Do the graph. Excel?
sure, but as Charles mentioned, y=total measured mass vs. x=number of marbles. To find the number of marbles I need the mass of one so I wanted to know how you can say its 4.5 g
The increments are about 4.5 other than the missing 16. This is a very simple graph to draw by hand=if you have some graph paper it helps. Otherwise EXCEL is often used, but that can take some work to learn.
You only need the integer number of marbles to plot the data. I guessed the 4.5 because it seemed to give integers within reasonable error limits. The error in the mass obtained from the best fit line (slope) from the graph should be good to a few percent. This slope in the Millikan oil drop experiment gave Millikan the charge increment for little balls of oil, electron by electron as he irradiated them). A truly beautiful experiment.
Incidentally it is possible that all the changes in the graph involved always moving 2 marbles (or3 or4) but it is less and less likely More data would make it more certain.
Hello, after graphing, I got a slope of 4.49992 and a y-intercept of 3.00000061. Is this reasonable?
Please draw the graph. I don't think you graphed it, because I just graphed it, and I got round numbers, but not real close to 4.5, and certainly not 3 for the other number. The accuracy is only one decimal place or thereabouts.
If you want a shortcut to the graph, you can take the n=1 point the n=5 point, (n=number of marbles), and compute the slope between these two points. Once you know the mass of the marble, it is easy to compute the mass of the container without a y-intercept.
The graph is the preferred method=I used paper with 1/4" squares.
And I think the first data cluster is for n=1 marble so the mass of the container is ~6g. Good that you are on it!
The graph shows this answer very clearly, and I'm hoping the OP will draw the graph like I did to see this for himself.
