Finding Ix in Switch Circuit at Different Times
  • Topic: Engineering
  • Thread starter Thread starter jeuceda
    Circuit Switch
jeuceda
Assume that the switch in the figure has been closed for a long time and opens after in t=0.
Find Ix in a) 0- b)0+ c) 40ms
Circuit schematic with a 3V battery, two 30 Ω resistors in series on the left branch, a switch labelled t = 0 connecting to a right branch with a 10 Ω resistor and a 0.5 H inductor, and current i_x shown at the top wire.
Switch is opened in t=0, current flows only in the 10Ω resistor, Ix=3v/10Ω= 0.3A-> 0-
0+ --> 3v/10=0.3A
Not sure if both currents are the same, and for the 40ms, when solving the equation (τ=L/R) τ (tau) results in a small number.
Do you think it's possible for the current through an inductor to change instantaneously?
It might help to see your work for part c in order to check it.
No couldt change instantaneously.
this is what i have for part c
τ=L/R -> (500mH)/70Ω=7.14ms
i(t)= i(∞)-(i(∞)-i(0+))e^(-t/τ)
i(40)= ?
That where I am stuck
Hi jeuceda. :welcome:
jeuceda said:
when the switch is open Ix=3v/10Ω= 0.3A
What assumptions allow you to say this?
When the switch is closed Ix=0.3A
How did you calculate this?
Not sure if both currents are the same, and for the 40ms, when solving the equation τ (tau) results in a small number.
You mention an equation. What is your equation, exactly?
It is clearer when you include a phrase such as "at the moment before the switch is closed ...", or "once the switch has been open for a long time ...", to confirm precisely what you are talking about.
BTW, the diagram is ambiguous; it is not clear from the diagram whether at time t=0 the switch is opened after having already been closed for a long time, or whether it is being closed at t=0 having prior to this been open for a long time. The textbook's double-headed arrow would be better drawn with only one arrow head.
