Finding magnitude of displacement vector
The discussion centers on calculating the magnitude of a displacement vector based on Silas's movements. Silas crawls 1.5 meters east and 3.2 meters south, leading to a resultant vector calculated using the Pythagorean theorem. The correct magnitude of the net displacement vector is approximately 3.53 meters. Participants confirm that "magnitude" refers to the size of the vector, which aligns with the calculated value. The answer should be presented in a positive format, such as "3.53 meters."
ilovedeathcab
[solved] finding magnitude of displacement vector
Silas crawls 1.5 meters due East then crawls 3.2 meters due South. Find the magnitude of the net displacement vector. Make sure you do the following in your answer:
* include correct units
* make your answer correct within 0.02
* make your answer positive (because magnitudes are always considered positive)
* put your answer in a form like one of these:
o #.## m
o #.## meters
The question is worth one point, and there is a half point penalty for each incorrect submission.
i got a resultant vector of 3.534m but that was using pythagorean theorem (1.5squared+3.2squared)= 12.49---> square root 12.49=3.53 but i don't know what it means by magnitude...am i doing it right?
Magnitude just means size. It is exactly what you calculated.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
