What is the Maximum Height Achieved by a Soccer Ball Kicked at a 45° Angle?
A soccer ball kicked at a 45° angle for 3 seconds requires calculating its maximum height using the correct equations. The initial vertical velocity must be determined, as it cannot be set to zero. The appropriate formula for vertical displacement involves the initial velocity and time, and should account for the ball's trajectory. The discussion emphasizes the need to clarify the relationship between vertical displacement and time to find the maximum height. Understanding these principles is crucial for solving the problem accurately.
pennywise1234
A soccer ball is kicked at a 45° angle. If the ball is in the air for 3 s, what is the maximum height achieved
y=viy + 0.5 x ay x t
i used trig to get the vertical and horizontal components i got 2.2 for each side (as there the same with a 45 degree angle)
i used y=0 + 0.5 x (-9.81) x (3s)
is this right ^^
your equation is not correct.
i used y=0 + 0.5 x (-9.81) x (1.5s)Square root
is what i meant to put
I think you mean squared, not square root.
yes, sorry
You got 2.2 what? You don't know the velocity, so how can you get the velocity components?
What does your y0 represent?
y=o represents initial velocity. but it is not known like you said, so that is how i was able to get 11.05 but setting initial to 0
The initial velocity cannot be 0. Otherwise, with gravity being the only accelerator the projectile would go down.
It's possible to calculate your initial velocity though, assuming the projectile lands on level ground. Can you modify your relationship above to help you find this?
Setting it zero will get you nowhere. Create an unknown for it, v.
Your equation for y is suitable for a vertical displacement, not a vertical velocity. In terms of v, what would the vertical displacement be at time t? What is the vertical displacement when it lands?
I am trying to find displacement though
You are asked to find, eventually, the vertical displacement from launch to the highest point. I asked you what the vertical displacement is from launch to where it lands.
  • · Replies 38 ·
  • · Replies 22 ·
