Finding maximum in interference pattern
In a three-slit interference system, the first minimum occurs at an angular position of 5.00°, prompting the need to find the first maximum. The relevant equation is dsinθ = mλ/N, where the maximum corresponds to bright regions and the minimum to dark regions. The correct calculation involves using sinX = 3sin5°, leading to an angular position for the first maximum of approximately 1.66°. A common mistake noted was dividing by three instead of multiplying, which affects the result. Clarification on the definitions of maximum and minimum intensities was also provided.
Les talons
In a three-slit system, the first minimum occurs at an angular position of 5.00°. Where is the first maximum?
dsinθ = mλ/N
dsin5° = λ
dsinX = λ/3
sinX = 3sin5°
X = 1.66°
I'm not sure if this is the right equation to find the first maximum in the interference pattern. Also, is the maximum the bright region and the minimum the dark region? Thanks all.
I get 15,2o when I solve for X?
But your approach is correct, yes.
And yes, the maximum (intensity) is the bright region
and the minimum (intensity of light) is the dark region.
Likes Les talons
Oh geez, what a silly mistake of dividing by three instead of multiplying by three... :confused: Thanks for the feedback.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 34 ·
