Finding minimum friction for leaning ladder against wall
  • Thread starter Thread starter martinlematre
    Beginner
13 replies · 3K views · last reply
martinlematre
A uniform 15kg ladder whose length is 5.0 m stands on the floor and leans against a vertical wall,
making an angle of 25 with the vertical. Assuming that the friction between the ladder and the wall
is negligible, what is the minimum amount of friction between the ladder and the floor which will
keep the ladder from slipping.
(34 N)
torque = fperp * distance
I keep on writing stuff but never get the right answer (which is 1/2 tan theta * mg)
i have no idea how to get there. i keep mapping and drawing FBD and i can't get there... i think its my understanding of torque and not understanding where the pivot point on this ladder is...
anyone care to share
Can you show your work in detail?
ehild
ehild
sure 1 sec let me write neatly
okay past this point I am not sure what to do..i assume the force wanting it to slip is Force-> (the horizontal ocmponent of MG) so i try to equate Ff (Friction) to The Force -> (Fparallelsintheta) but i get the answer 68 not 34...
http://i44.tinypic.com/2vmvalg.jpg
i realize my problem lays in the fact i don't know what forces are acting on what and my free body diagram is probably wrong
The ladder is in rest, so the resultant force is zero and the torque is also zero.
You have vertical forces acting on the ladder: mg and FN (from the ground) and horizontal ones: FWN (the normal force from the wall) and the force of static friction, Ff.
How are the magnitudes of these forces related?
The forces have torque. Choose an appropriate point to write it up.
ehild
ehild
this doesn't help me =[
You do not need Fparallel. Write up the equilibrium for both the vertical and horizontal forces separately.
my problem is i don't know what forces are where
See figure. It is identical to your one.
mg acts at the midpoint of the ladder, vertically down. FWN acts at the upper end of the ladder, horizontal, away from wall. N and Ff act at the lower end of the ladder, N vertically up, Ff horizontally, towards the wall, as it is against slipping the ladder outward.
  • Free-body diagram of a ladder leaning against a vertical wall: blue FWN points horizontally away from the wall at the top, magenta mg points down at the midpoint, green N points up and orange Ff points toward the wall at the base.
The ladder is a rigid body. To be in equilibrium (no motion) the sum of all forces has to be zero both the horizontal and vertical components. Also the torque has to be zero.
Do you see the forces? The ladder can not move vertically, so what forces have to cancel?
It can not move horizontally, so the horizontal forces have to cancel.
It can not rotate about its upper end so the sum of torques is zero.
Can you write up the corresponding equations?
ehild
ehild
i got it no biggie
ehild said:
So you have solved the problem?
ehild
No I've just decided I am going to go into liberal arts instead
