Finding n such that n-2 divides n²-n+3
42 replies · 5K views · last reply
mtayab1994
Solve for n in the following equations:
[tex]n-2\mid n^{2}-n+3[/tex]
Should i use the euclidean division to solve it? Thank you before hand.
Edit: When i used euclidean division i got n+1 and a remainder of 5 but i don't know how to get n.
Start by using the definition of divides to produce an equation. This equation will introduce a new variable, say, k. Solve for n using the quadratic formula (which will involve k) and then choose values of k so that n is an integer (I assume n is an integer in this problem).
See what you come up with!
So that means you should get: n^2-n+3=k(n-2) am i right?
Mark44 said:
Right.
Yes now how can i continue from there?
Whovian said:
Ever heard of quadratic equations?
Yes, but n^2-n+3 doesn't have any real roots, if that's what you're talking about.
No, we group everything on one side of the equation so we have coefficients in terms of k and solve THAT.
So we get: n^2-k(n-2)-n+3=0, but where are we supposed to get b^2-4ac. Is b=k(n-2)?
Not quite. We get n^2-(k+1)n+(2k+3)=0 after multiplying out and grouping like terms, and it should be obvious how to proceed from here.
So for Δ i got k^2-6k-11 and then i counted the discriminant again and i got 80. Is what I've done so far correct?
Mark44 said:
Reread what scurty wrote in post #2. He laid out pretty much what you need to do.
So there is no need to find the discriminant of the equation : n^2-(k+1)n+(2k+3)=0?
Mark44 said:
I don't see any need for finding the discriminant in this problem.
But the quadratic formula involves finding the discriminant, or do i just use random values of k?
Of course you find the discriminant in the quadratic formula. What I meant was that there's no reason to find it and stop there.
Again, take a look at what scurty said in post #2. You are asking questions that suggest you haven't read it or didn't understand it.
Well, he said to produce a new equation, which I did and then he said to find n using the quadratic formula, which will involve k, and that's what I did. I'm confused because we have just started this lesson, and we haven't done any problem like this so far.
Mark44 said:
Did you solve the quadratic equation for n? If so, what did you get?
For n^2-(k+1)n+(2k+3)=0 I got a discriminant of k^2-6k-11 then i solved that equation and I got Δ=80 so i got k1=3+2√5 and k2=3-2√5.
Mark44 said:
Solve n^2-(k+1)n+(2k+3)=0 for n[/color].
Ok when solving for n i got : [tex]n=\frac{k+\sqrt{k^{2}-8k+4}}{2},\frac{k-\sqrt{k^{2}-8k+4}}{2}[/tex]
No.
Do you know how to use the quadratic formula? You said before that the discriminant was k2 - 6k -11, but that's not what you show above.
Mark44 said:
No.
yes instead of k^2-8k+4 should be k^2-6k-11
I think i got it for k^2-6k-11=0 we get n =(k+1)/2 right?
For what it's worth, when I solved this, I got 4 answers for n. I'm not sure if there is a theorem that's states a maximum number for n based on certain criteria, but I tested out about 30 values for k and only two of them worked. Maybe someone else can chime in.
Well after all you really don't need to form and equation and give values for k all you have to do is:
[tex]n-2\mid n^{2}-n+3\Longleftrightarrow\frac{(n-2)(n+1)+5}{n-2}\Longleftrightarrow n+1+\frac{5}{n-2}[/tex]
and since: [tex](n+1)\in Z[/tex] therefore: [tex]\frac{5}{n-2}\in Z[/tex]
thus: [tex]n-2\mid5[/tex]Then you form a table with 2 rows one row contains the divisors of '5' and the other row contains n the number that we have to plug into n-2 to get that divisor of 5. Like the following.
(n-2) 1 -1 5 -5
(n) 3 1 7 -3
And then the solutions are: [tex]S=\{-3,1,3,7\}[/tex]
So how's that? I think my way is a lot easier then solving all of those equations.
Those are the answers I got. There are often more ways than one to solve a problem, in this case, that method would probably be the easiest way to solve the problem. However, you seemed to struggle with simple algebra involving solving for a quadratic equation.. You might want to touch up on that a bit for the future. Algebra techniques are common in number theory, I remember using the quadratic formula numerous times when I took the course, it would be wise to understand why the other method works as well.
Edit: I just noticed that you don't have k anywhere in your equation. The definition of divides introduces a new variable, you can't just assume k=1, you have to explain why certain values of k work and others don't. It works in this case but not all cases.
Sorry for butting in, but I like to think of myself as a decent mathematician who has terrible difficulty with number theory.
I couldn't solve this at all. I had to write a program to solve for all cases for 1 to 1000 and I got the same answers: 3 & 7
Could someone please tell me where I'm going wrong analytically?
PS I've read post #2.
