Finding Net Force with the Coefficient of Friction
To find the net force on a 51kg child sliding down a 42-degree slide with a coefficient of friction of 0.10, the normal force (Fn) is calculated as 379 N. The frictional force opposing the motion is determined to be 38 N. The net force acting on the child is the difference between the gravitational component down the slide and the frictional force. The discussion highlights the importance of understanding the forces at play, including gravity and friction, to solve for net force. This approach is essential for determining how far the child will slide before reaching a speed of 2.5 m/s.
triamanda
A 51kg child goes down a 42 degree slide. What is the normal force on him? If the coefficient of friction is .10, what is the net force on him? How far down does he slide before reaching 2.5 m/s?
Fk = μFn
F = ma
Fn = 51gcos(42)
= 379 N
I have no idea what to do to find the net force.
the component of the child's weights acts down the plane. Friction acts up the plane.
Also for a normal force N, the frictional force is given by μN.
Can you find the resultant force now?
I believe so:
.10(379) = 38 N
Thanks!
