Finding Orthogonal Vectors in R4 with Norm 1
22 replies · 5K views
sevag00
Find two vectors in R4 of norm 1 that are orthogonal to the vectors u = (2, 1, −4, 0),
v = (−1, −1, 2, 2) and w = (3, 2, 5, 4).
What i did was, i let a vector x = (x1, x2, x3, x4) that has a norm of 1 and orthogonal to u,v and w
i.e. x.u = 0; x.v = 0 and x.w = 0.
This where I'm stuck. Some help would be appreciated. Thanks.
hi sevag00! :smile:
(try using the X2 button just above the Reply box :wink:)
hint: how would you find a vector (x1,x2,x3) orthogonal to (a,b,c) and (d,e,f) ? :wink:
Using dot product. x1.a + x2.b + x3.c = 0. Same for (d, e, f).
Yeah, but the chapter only explains the dot product. So, i think the problem should be solved using dot product.
ok, in that case you have three simultaneous equations (from the dot products) …
solve them the usual way :smile:
3 equations with 4 unknowns. Will this yield a solution?
3 equations with 3 unknown ratios :wink:
so yes, you can find the ratios :smile:
Ah yes. 4 equations with 4 unknowns.
tiny-tim said:
how about the cross product ? :wink:
Further, the cross product is defined only in three dimensions while this problem is in four dimensions.
Wait a minute. You got me confused. There are 3 equations with 4 unknown. The equation of the norm cannot be included with the other three.
HallsofIvy said:
Further, the cross product is defined only in three dimensions …
i was talking about three dimensions
there are only three unknown ratios
so you can find the ratios
What ratios? I want to find the components of x.
Not getting your approach.
divide your three dot-product=0 equations by x1
that gives you three equations in x2/x1, x3/x1, and x4/x1
then solve them :smile:
I think i did it right. I replaced x2/x1 with X x3/x1 with Y and x4/x1 with Z. Then solved 3 equations with 3 unknowns.
You can write the three equations in four unknowns as three equations in three unknowns but with the fourth unknown on the right-hand-side. In other words, you can express three of the x_i as functions of the fourth. For example, you can write the second equation ##-1 x_1 - 1 x_2 + 2 x_3 + 2 x_4 = 0## as ##-1 x_1 - 1 x_2 + 2 x_3 = -2 x_4##, or ##x_1 + x_2 - 2x_3 = 2x_4##. Do the same thing for the third equation; the first already has the right form. Now you can solve for ##x_1, x_2, x_3##; this will give them as formulas involving ##x_4##.
BTW: the method above is a standard way of dealing with such problems; it is used all the time in such fields as linear optimization (linear programming).
I know that method. But then those equations will become parameters. They will depend on the value of x4 which has infinite solutions.
Of course; that is the whole point. So, if you want to find two different solutions, just give two different values for ##x_4##---any two values you like, except 0. (Putting ##x_4 = 0## gives the zero vector, which cannot be normalized to length = 1!)
I want direct solution for the x-es. I'm not going to plug in millions of values to see if the norm is 1.
put x4 = 1, then normalise it
You have completely misunderstood what some of us have been saying. First find two vectors that satisfy the perpendicularity conditions. THEN normalize them.
For example, if I start with a vector like ##v = (1,2,3,4)## I can get a normalized version as
[tex]u = \frac{v}{\text{norm of }v}[/tex]
If v was perpendicular to some vector w then so is u, and u has norm 1. That's all there is to it.
