Finding output voltage and waveform for silicon diode circuit
  • Topic: Engineering
  • Thread starter Thread starter servehover
    Circuit Diode circuit
36 replies · 7K views · last reply
servehover
Circuit schematic of a transformer secondary feeding a 1K resistor in parallel with two oppositely oriented silicon diodes, output labelled Vo; secondary marked 1V_RMS.
Find Vo and draw the waveform. The two diodes are silicon diodes with a voltage drop of 0.7V.
(given by my teacher)[/B]
Id = Io * (e^(qv/nkt)-1)
Vp = Vrms * sqrt(2)
Vrms = Vp/(sqrt(2))
I have no idea how to find Vo or the waveform.
servehover said:
Handwritten circuit schematic: a transformer secondary labelled 1 Vrms feeds a 1K resistor in parallel with two oppositely oriented silicon diodes across output terminals labelled Vo.
Vp = Vrms * sqrt(2)
Vrms = Vp/(sqrt(2))
Welcome to Physics Forums!
What is the input ac voltage? What is the turns ratio of the transformer?
Neither are given
Vp = Vrms * sqrt(2)
Vrms = Vp/(sqrt(2))
Not really relevant here. You are given the diode voltage drop as 0.7V which applies in this case as soon as some current goes thru the diodes.
It's a bit misleading. For a hint, realize that ther secondary voltage of 1V rms is WITHOUT THE DIODES. Why? You need think about this, then you shoulsd be able to draw the output waveform.
servehover said:
Neither are given
Oh..actually neither is required. I didn't read "1V rms" written on the secondary. So the input to the diode circuit is 1V rms.
Hint: There is no series resistance between source and the diodes.
Would the output voltage v0 simply be 1Vrms? Is it because the voltage across the 1k resistor is also 1Vrms?
Yes.
cnh1995 said:
Yes.
Any hints for something like this?
Circuit schematic of a full-wave center-tapped rectifier: a transformer secondary with two 12.6 V RMS halves and a centre tap to ground, two diodes feeding a node Vo, a 1k resistor and a 5.6 V Zener diode across Vo.
No.
The diodes are limited to 0.7V as given in the problem. So the voltage across the diodes can't possibly be 1V rms = 2.82V peak-to-peak when the peak-to-peak is limited to 2 x 0.7V = 1.4V.
(In "real life" either the transformer impedances are high enough to limit the current or the poor little things would burn out, in which case you really would have 2.82 V pk-pk. The 1K resistor does nothing except get hot).
(In
Hand-drawn full-wave rectifier schematic: center-tapped transformer secondary labeled 12.6V RMS on each half, two diodes feeding node Vo, a 1k resistor load and a 5.6 V Zener diode to ground.
Same basic idea. Vo is limited to 5.6V. You need to think graphically about Vo as it rises from zero to the max. voltage . That also applies to your previous problem BTW.
rude man said:
No.
(In
So V0 would be 0.4949Vrms? (0.3535 * Vpp)
But the source (transformer secondary) is connected directly across the diodes. There is no series resistance given in the problem (like secondary winding resistance). If the diode voltage is less than 1V rms, where did the remaining voltage go? Doesn't that violate KVL? A diode clips the voltage across it to 0.7V only when there is an impedance in series with it.
Edit: I see you already explained it in the last para of your post, but if the transformer impedance is not mentioned, should we assume some nonzero impedance or should we ignore the transformer impedance and write the diode voltage as 1V rms?
As the answer is dependent on unclear assumptions there is surely an error in the diagram.
I suspect the 1k resistor should be in series with the transformer secondary.
I agree the problem is confusedly stated. But since it's stated that the diode voltage is 0.7V the only reasonable assumption is that the 1V rms is the no-load voltage across the secondary of the transformer.
Assuming sufficient transformer impedance that the diodes don't burn out, what you need to do now is draw a picture of what Vo looks like, then compute the rms voltage accordingly.
I am still kind of lost as to how I get Vo.
The two diodes are in parallel, so would the voltage drop across both diodes be 0.7V?
Is Vo simply 0.7Vpp?
The diodes are connected "back-to-back" so only one is "on" at a trime.
Ask yourself what Vo would look like without the diodes, then figure out what function the diodes perform. Do they alter the sinusoidal shape of the unloaded Vo? How?
If the diodes were removed, Vo would simply be 1Vrms. Voltage drop across a diode is 0.7V so the output voltage has a peak of 0.7V. Would the output waveform simply look like a sine wave with a peak of 0.7V?
Summarizing the discussion: there are at least two correct answers to this problem, according to the assumption being made that:
(1) the transformer is ideal and the diodes are logarithmic Silicon (i.e., characterised by the exponential current equation your teacher provided), or
(2) the transformer is a practical transformer having some resistance and the diodes can be modeled as having an approximately constant voltage drop while forward biased.
or (3) some combination of (1) and (2).
In the absence of clarifying information from your teacher, it may be worth your while preparing separate answers for both (1) and (2).
⏩ Is your teacher known for setting trick questions designed to make you really think?
A peak of ±0.7V, certainly, but not a sinewave.
Yes
Would it be a rectified sine wave?
Waveform of six identical positive arches sitting on a horizontal baseline, each rising from zero and returning to zero, like a full-wave rectified sine wave.
Yoou're getting closer, but Vo would not look like a sine wave although it would indeed have peaks of 0.7V.
servehover said:
YesWould it be a rectified sine wave?
No. Why rectified? How can there be one polarity but not the other when the diode connection is perfectly symmetrical as far as polarity is concerned?
Waveform of six identical arch-shaped humps sitting side by side on a horizontal baseline, touching the baseline at their junctions, like a full-wave rectified sine wave.
Would it go from 0 to 0.7 or -0.7 to 0.7? I really don't understand the problem(s) and neither do any of my classmates.
Assuming sufficient transformer impedance in series with the diodes, the diodes "almost maintain" 0.7V across them when forward biased. See NascentOxygen's post #19 (2nd point). Look up "diode clipper" circuit.
So it would basically be a sine wave but clipped at 0.7V?
Edit: this circuit has the resistor in series though. Mine is in parallel
Circuit with a sine wave source V_IN in series with resistor R1, feeding two antiparallel diodes D1 and D2 across V_OUT; at left, a sine waveform of amplitude +V_P to -V_P and at right, the output waveform clipped at +0.7V and -0.7V.
Circuit schematic of two anti-parallel silicon diodes D1 and D2 clipping an AC input V_IN through series resistor R1, with output V_OUT, beside a sine input waveform and clipped output waveform marked at +0.7V and -0.7V.
Exactly!
But this is true only if sufficient impedance is assumed in series with the diodes (like the R1 resistor in your image). Without that, the diode voltage will simply be equal to the source voltage i.e. 1V rms.
cnh1995 said:
Exactly!
Does the resistor in parallel changed anything vs the resistor in series?
My teacher is the kind of guy to give trick questions, so I'm really leaning towards the 1V rms answer...
Can you give me any hints regarding 2nd problem?
Me too, especially after knowing about your teacher. Maybe he wants to see if you get confused with the parallel 1k resistor and 0.7V diode drop.
Parallel resistor doesn't make any difference here. The circuit would work the same way even if it weren't there. It's the series resistance that is required for the clipping action.
Can you explain this? If there is no series resistor in my problem (it is parallel), does that mean there is no clipping in my problem?
Do you have any hints for these two?
Two schematic circuits: top, a 6.3 V AC center-tapped transformer feeding a diode bridge with outputs Vo1 and Vo2 across two 1k resistors; bottom, a 10 V RMS transformer feeding a diode bridge with a 1k load resistor and a Zener diode labelled 5 across output Vo.
