Finding shaft twist angle between two points
  • Thread starter Thread starter Omg999
    Degrees
4 replies · 2K views
Omg999
Hi!
I need help with a task. I have done previous calculations on the shaft, but I'm stuck now, as I'm going to find out how many degrees the shaft is twisting from point C to D. I have calculated bending/shear stress, torsion stress and the last stress that i don't know in english, but the formula is like this:
So I am wondering if anyone has done this before?
Welcome to the PF. :smile:
Can you post a diagram of the shaft and how it is being held and torqued? Use the UPLOAD button in the lower right of the Edit window to attach a PDF or JPEG file to your reply. Thanks.
Thank you! :)
The picture of the shaft with belt transmission is showed in task 6.1 The describtion is in norwegian, as I'm from Norway. I have done task a) b) c) and d). Now, task e) says: How many degrees will the shaft twist between point C and D? Elastic modul is given 81.300 N/mm^2.
Please see the other picture with the equation marked in red: I think that is the correct formula to use, but I can't seem to get a realistic answer.. The answer should me 0,... something but I get 58.8.
Do you know about theta=T*L/(J*G)?
