Finding Shear Centre of Lipped Channel
  • Thread starter Thread starter Seven7
    Channel Shear
This discussion focuses on the calculation of the shear centre for a lipped channel cross-section. The centroid was determined at x(bar) = 40.28mm and y(bar) = 150mm, with the second moment of area calculated as Ixx = 9.04x10^7 mm^4. The Q-distribution was derived for three sections of the channel, leading to shear stress calculations under a 100KN load. The user seeks guidance on the appropriate bounds for integration in their calculations, indicating potential errors in their shear stress distribution assumptions.
  • Understanding of shear centre calculations in structural engineering
  • Familiarity with the concepts of centroid and second moment of area
  • Knowledge of Q-distribution and its application in shear stress analysis
  • Proficiency in integral calculus for evaluating shear stress distributions
  • Review the principles of calculating shear centres in lipped channels
  • Study the application of the first moment of area in shear stress analysis
  • Learn about the significance of bounds in integral calculus for engineering applications
  • Explore advanced topics in structural analysis, such as shear flow and moment distribution
Structural engineers, civil engineering students, and professionals involved in the design and analysis of channel sections and shear stress distributions will benefit from this discussion.
Seven7
The figure shows the cross-section of a lipped channel;
http://img149.imageshack.us/img149/6324/88754244yh7.th.png
I need to locate the shear centre based this.
Second moment of area / inertia; Ixx = (1/12)bh^3 + Ay(bar)^2
First moment of area; Q = A*y(bar)
Firstly, I located the centroid of the shape. I found it to be at x(bar) = 40.28mm and y(bar) = 150mm.
Secondly, I found Ixx (the second moment of area / inertia) for the shape. I found Ixx = 9.04x10^7 mm^4.
Next I worked out the Q-distribution for the cross-section (refer to image below);
http://img144.imageshack.us/img144/6072/10584649lt5.th.png
For the first section labelled 1;
Q = 15s(150 - s/2) = 2250s - 15/2*s^2
Intuitively, (or by taking the derivatives) we know the maximum value for s will be 150;
Q(150) = 1.688x10^5 mm^3
For the section labelled 2;
Q = 1.688x10^5 + 15s x 150 = 1.688x10^5 + 2250s
Same as before, s = 100 is the maximum;
Q(100) = 1.688x10^5 + 2250(100) = 3.938x10^5 mm^3
Finally for section 3;
Q = 3.938x10^5 + 10s(150-s/2) = 3.938x10^5 + 1500s - 5s^2
Q(150) = 3.938x10^5 + 1500(150) - 5x(150)^2 = 5.063x10^5
Next I assumed that the cross-section was loaded through the shear centre with a force of 100KN. The idea being that I can resolve the Q-distribution on the webs of the cross-section and then take moments about a certain point and find the shear centre.
In order to do this I tried to find the area under the Q-distribution diagram. For the purpose of this question we can ignore the section labelled 2 (because the only applied shear is vertically through the shear centre;
For section 1;
T1 = VQ/It = 100000 N / 9.04x10^7 mm^3 x 15 mm x (2250s - 15/2*s^2)
T1 = 0.1659s - 5.5313x10^-4*s^2
Now taking the integral;
integral T1*15ds = 15 x ( (0.1659/2*s^2) - (5.5313*10^-4/3*s^3) )
****** Here is where I get stuck ******
I'm not sure what the bounds of integration should be on the first section. I'm not sure whether it's 0 to 30; 270-300; or even 130-150. Any advice / direction would be greatly appreciated.
In addition to this;
T3 = VQ/It = 100000 N / 9.04x10^7 mm^3 x 10 mm x (3.938x10^5 +1500s - 5s^2)
T3 = 43.562 + 0.16593s - 5.531x10^-4*s^2
integral T3*10ds = 10 x (43.562s + (0.16593/2*s^2) - (5.531x10^-4/3*s^3) )
This is bounded between 0 and 300 so we get;
integral T3*10ds = 15756.75 N = 157.6 KN
If this is correct then we can expect that section 1 will be taking roughly 50KN of shear stress across the two small lips; i know this is the case because by doing a simple for balance, we know that the sum of forces in the y-direction for the 3 sections of the web (large body and 2 small lips) will sum to 100KN (the applied force); 50KN on the small lips sounds a bit large, so I'm thinking there is something wrong in the method up until this point.
Thanks for any help guys.
Since the links are now broken, it is impossible to comment.
