Finding Speed and Volume Flow Rate in a Constricted Pipe
The discussion revolves around fluid dynamics, specifically applying Bernoulli's equation to a problem involving water flow through a constricted pipe. The scenario includes varying pressures and diameters at two points along the pipe, with participants exploring how to determine the flow speed and volume flow rate.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of Bernoulli's equation and energy conservation principles. There is an exploration of how to relate the velocities at different points using the continuity equation. Questions arise regarding the interpretation of constants in the equation and the correct setup for solving for flow speed.
Some participants have provided guidance on using Bernoulli's equation and continuity to relate the flow velocities. There is an ongoing exploration of the calculations involved, with some participants sharing their results and checking for consistency in units and values. Multiple interpretations of the problem setup are being considered.
Participants note the importance of ensuring that the assumptions regarding incompressibility and energy conservation are valid for the problem at hand. There is also mention of potential discrepancies in numerical results due to rounding.
xray2golf
Water moves through a constricted pipe in steady, ideal flow. At one point, where the pressure is 2.50*10^4 Pa, the diameter is 8.0 cm. At another point .5 Meters higher, the pressure is equal to 1.50*10^4 Pa and the diameter is 4.0cm. Find the speed of flow at the lower and the upper sections and also find the volume flow rate through the pipe
I don't really care about the volume flow rate at this point, am really interested in how to find the speed of the flow at one of the sections, say at the lower section where the altitude would equal zero.
P1+(Rho)(g)(y) + 1/2(rho)(V)^2 = constant
Insert pressure at lower point for P1
Zero height eliminates rho g y
Insert density of water for rho
Leave V as V, since that is what we are solving for
Dont know what to insert for constant.
At this point, I am at a loss...constant is a variable? Does that give two variables and how then solve?
Recall back to solving problems with energy conservation, this is similar (actually the same, bernoulli's equation is just a by-product of energy conservation...kool isn't it? *insert nerdiness*)
Well, constant usually means the atmospheric pressure (if there are any) or 0.
I tend to do these problems differently. I look at the initial and set it equal to the end. Since energy is conserved (which is what Bernoulli's Law states), then the initial energy must equal to the final energy. (and everything is analogue to what they look it in energy conservation, except m becomes rho - for a reason too)
You have not written the equation correctly. The equation does not state that the initial conditions + final conditions = constant. It says that any condition = constant. Because of this, we can say that the initial condition = final condition.
So let's look at what you were given. You have pressures at both inlet and outlet, along with a delta z. The only remaining terms are velocity components. So, we have one equation, and two unknowns. We can't solve this directly, so we'll need another equation.
Luckily, the since our flow is incompressible, we can get a relationship between the two velocity terms. From continuity:
[tex]\dot{m}_{in} = \dot{m}_{out}[/tex]
Or:
[tex](\rho A V)_{in} = (\rho A V)_{out}[/tex]
Since the density remains constant, we can solve for either the inlet or outlet velocity.
[tex]V_{in} = \frac{A_{out}}{A_{in}}V_{out}[/tex]
Plug that into the equation, and now we have one equation with one unknown. Solve.
Hunter made a good point that should be remembered. Bernoulli's equation is derived DIRECTLY from conservation of energy. It basically says the energy at one point is equal to the energy at another point plus any any work that has come in minus any work that the fluid put out. It says that between two points, the energy in the fluid can be transferred between potential energy (z), kinetic energy (velocity), and pressure.
Or:
Ok, by solving [tex]V_{in} = \frac{A_{out}}{A_{in}}V_{out}[/tex] with the actual data,
[tex]V_{in} = (12.6/50.3)V_{out}[/tex] or [tex]V_{in} = .250V_[out][/tex]
I assume I plug that into the original P[tex]_{}1[/tex] + [tex]P[/tex]gy + 1/2[tex]P[/tex] V[tex]^{}2[/tex] = constant or into the longer version? (sorry, I am struggling with the Latex)
I will try and work the math on paper and come back with my answer.
Thanks
OK,
I plugged Vin = .250Vout into the original Bernoulli's equation and ended up with V2 = 3.30.
(25000) + (.5)*(1000)*(.250V2)^2 + (1000)*(9.8)*(0) = (15000) + (.5)*(1000)*(V2)^2 + (1000)*(9.8)(.5)
V2 = 3.30
If this is correct then I will plug that answer back into the equation and solve for the exit velocity.
Quickly looking at it looks correct; do make sure that your units work out, and tha your sign notation is correct.
I got V1 to equal .831
When I plug these numbers into the equation for flow rate through the pipe I get very close numbers at both ends...41.8 m^3/sec and 41.5 m^3/sec.
I assume the rounding could be the reason for the difference...the bottom line is the numbers are the same, as the should be throughout the pipe.
Thanks for the assistance.
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 16 ·
