Finding speed using energy equations
  • Thread starter Thread starter asdf12321asdf
    Energy Speed
The discussion focuses on solving a physics problem involving two masses connected by a string over a frictionless pulley. The key equations for energy conservation are presented, but the initial attempt at calculating the final speed of the 8.00 kg mass is incorrect due to miscalculating potential energy. Clarifications are provided regarding the correct potential energy values for each mass at different heights. After correcting the mass values and combining the energy equations, the user successfully finds the correct speed. The exchange highlights the importance of careful calculations in energy problems.
asdf12321asdf
Two masses are connected by a light string running over a frictionless pulley as shown below. The system is initially at rest and the incline is frictionless. If m1 = 10.0 kg, m2 = 8.00 kg and the incline makes a 30o angle from the horizontal, use energy methods to find the speed of the 8.00 kg mass just as the 10.0 kg mass reaches the ground 4.00 m below. (Hint: Think about how far the second mass will rise vertically as the first mass drops 4.00 m downward.)
KEf + Uf = KEi + Ui
(.5)mvf² + mgyf = (.5)mvi² + mgyi
I'm really not sure what to do here. Here is one of my attempts.
(.5)(18)(vf)² +(18)(9.8)(0) = (.5)(18)(0)² + (18)(9.8)(4)
Solving for vf I get vf = 8.854, which is not the correct answer.
I'm pretty confused here and am not even sure if I am using the equation I need to be using. Any help would be greatly appreciated.
Thanks
KEf + Uf = KEi + Ui
Thanks
You essentially have the right equation, but you are not correctly calculating the potential energy U correctly. For example, initially, one mass is 4 m above ground, and the other is at the ground. They have different potential energies, both initially and finaly. They do, however, have the same speed, so your Kinetic energy terms are correct.
Ok I got that Yf of mass2 is 2. And if I write the equation for each mass I get:
mass1
(.5)(18)(vf)² + (18)(9.8)(0) = (.5)(18)(0) + (18)(9.8)(4)
mass2
(.5)(18)(vf)² + (18)(9.8)(2) = (.5)(18)(0) + (18)(9.8)(0)
Is that right? Does that help me at all?
Why are you sing 18 kg as the mass of mass 1? And 18 kg as the mass of mass 2? Correct those numbers. Then add up both equations to get the total initial energy and total final energy. Otherwise your equations are correct for the y terms in your U calcs.
Thanks a lot! I changed the weights and then added the two equations and solved for vf and ended up with the correct answer. I was pretty clueless as to how to solve this question initially, but now I think I am starting to get it. Thanks again!
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 16 ·
